transmission cooler question
hey u guys i just purchased a Stage II VB mod. so i need a tranny cooler.
I am looking at 2 of them on ebay.
the hayden 1401 and 1402
here are the links.
1401:
http://cgi.ebay.com/ebaymotors/Autom...88110538QQrdZ1
1402:
http://cgi.ebay.com/ebaymotors/Autom...88110553QQrdZ1
the 1402 is bigger and looks to be for a more heavy duty application.
is there anything bad about a bigger cooler? which one should i go with...1401 or 1402?
here are the links.
1401:
1402:
For mild/cooler climates, I suggest getting one with a thermal bypass so the ATF doesn't flow through the cooler if the temperature is too cold. B&M makes them and I think Hayden now has a stacked plate design with bypass as well. Up to 19,000GWV is adequate.
Otherwise, get the 1402. Use synthetic ATF while your at it.
I was going to say, the 1401 is what I have and it's not big enough, IMO. It does its job ok, but not as well as I would like. A thermal bypass of some sort would also be nice.
I'll be switching to dual B&M units this summer, but I also have plans
dual cooler in series one after the other?
sctludwig
Sep 1, 2022 01:32 PM
The Wizard
24
Oct 1, 2015 08:47 PM
