Spacer Mod, interest needed
Originally Posted by hacim105
The problem is we have no test vehicle. So I don't think anything is going to come about with this.
Originally Posted by 90stanza
Have you tried searching for people in the regional forums?
Adding this thick piece of gasket to the manifold will lengthen the runners, therefore changing your HP and torque peak lower on the rpms. Longer runners=more velocity which then moves the peak down on the chart. Tested this on a 5.0 and would be the same for maxima.
Originally Posted by supazn
any update?
Don't get your hopes up too much. It all depends on how hot your intake manifold gets with the stock setup. If I think there are potential gains to be had, then I will produce the spacers. We'll see.
Originally Posted by stephenlc
this is for the lower intake manifold right? The one with the thin metal gaskets? The intake manifold gasket between the upper and lower is already plastic/rubber type gasket.
TonyJr
Aug 20, 2015 12:14 AM
