Idler Pulley Nut Stripped
Old Mar 13, 2007 | 10:25 AM
Powerman5115's Avatar
I tried changing my belts yesterday and the idler pulley nut is stripped. Anything I try will not work. I've tried a serpintine(spell?) belt tool, closed in wrenches, and a monkey wrench (it won't fit because of the small space). The only thing I know of now is vice grips or take it to the shop. I have a torch to heat the nut up but don't know if it will come off since it is stripped. I would really like to do this myself and not have anyone else touch my car. Let me know if I haven't tried something.
Old Mar 13, 2007 | 12:26 PM
MDeezy's Avatar
that is a tricky space to get into.
since you are changing your belts I assume the serpentine is in bad shape and has to be changed anyway.
Cut the serpentine, and then remove the tensioner pulley by the 3 x 12mm bolts. then you'll have the whole thing off the car, and have much more room to manuver that bolt off. Try not to damage the threading and you can go to home depot and get another nut to fit onto it.
Old Mar 13, 2007 | 07:31 PM
4x4Max's Avatar
there are vice grips that will fit down there, my friend has some and i used them on my car when changing the belts. Just try to find the correct vice grips and you're set.
Old Mar 14, 2007 | 12:21 AM
ewuzh's Avatar
Soak it in liquid wrench. Grab a large flat head and wedge it between where the nut contacts the pulley. Then grab a hammer and give the flat head a few good whacks. Then try again with the vice grips. It will come off.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
