a couple light questions.. please read
Old Jul 8, 2001 | 08:05 PM
bdogg88's Avatar
lateely my lights have been acting up.. i have HID replacements in and just about every 3rd time i turn on my lights one is out, so i have to open the hood, and push it or pull it (it = the back of the halogen bulb) and then it works again.. what's up w/ that... i also noticed that when my alarm goes off, only 1 headlight flashes
also, should i get my reverse lights the polarg kind, does that look good on '96 max's...
Old Jul 8, 2001 | 08:15 PM
Vyrus's Avatar
RE: Loose Wires?
First, check and see if the bulb is in its socket tightly. You might also want to check and see that the bulb's prongs/metal parts are not bet (and if they are straighten them). Also, check the wires going into the bottom/back of the assembly and bulb casing. I know these are standard procedures, but many people overlook them thinking that can't be it. Just try it, because it requires no money and you can't go wrong. Just trying to help.
Old Jul 9, 2001 | 06:01 PM
nelzavala's Avatar
Sounds like you fried your harness
Could be that you burned the harness, I had the same exact problem until I noticed that the plug itself (the holes where the prongs go)had melted. Make sure you still have the holes where you plug the bulbs. You may need to replace the harness'.
trasmadean
Jan 20, 2018 05:05 AM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 5, 2015 09:02 AM
yat70458
Aug 3, 2015 01:16 PM
