Budget Catalytic Converter: Bullet style or OEM?
I'm finishing up my exhaust, and checking out cat's just to get it all done at once. I was looking at budgets website and there's two options (well more, but I'm looking at these two):
Bullet Style High Flow Cat, 2.0/2.5/3.0 Inlets (Part# CATxx01)
$80
OR
High Flow Cat, 1.75/2.0/2.25/2.5/3.0 Inlets (Part# CATxx04)
$90
$110 for 3.0 Inlet
Here's a link to budgets site:
http://lssexhaust.com/
Do the bullet style fit our cars? It's cheaper, and should I stick with a 2.5" Inlet?
(I'm going from stock to: CE Y-Pipe, Budget Cat, SP2) Stock tubing is 2.25" right? But stock cats are 2.5"?
$80
OR
$90
$110 for 3.0 Inlet
not sure if those will fit but i know you should not get a smaller cat than what your stock one was or it will get wayyy to hot and sh*t the bed pretty quickly. i actually heard a story about a car that got a 'universal' cat put on that was smaller than the stock one and it was glowing bright red and burnt a hole in the floor.
best bet is to check to see if they have sizes/dimensions on their website and measure your cat and get the one thats the same size.
Looking at the pictures I'm probably going to go with the CATxx04, it looks the largest and closest to what I already have, and go with a 2.5" inlet since I believe that's stock, and it will line up with the rest of my exhaust
yea that'll probably work. thats the one i would get too if i were you. plus its $90 canadien, so itll only be like $80-85. theres a possibility you will get a code for the cat though since its high flow.
edit: ide stick with 2.5" too...3" is a little much for a naturally asperated engine
there really is no point in u changing ur catalytic converter, since the stock one is already 2.5 inches, which is the size of almost all of the aftermarket ypipes and b pipes in the market today for our 4th gens... so save urself a little money and just stick with stock
Currently everything does not line up, B-Pipe is bent out of shape, and I just want to junk the whole system and start off fresh
Originally Posted by jxkim
buy it from warpspeed
The cats. from LSS, you have to get welded on. I got mine from Warpspeed,
with flanges already welded on , so I could just bolt it up.
Don't use the gaskets he supplies, they burn up in a few weeks and cause exhaust leaks!
Get some metal ones from Nissan or a custom exhaust shop.
Give Dallas a call at Warpspeed:1-866-801-9338
Originally Posted by maxima985spd
i recommend budget LSS high flow cats they come with the flanges welded on and fitment is excellent. do not do with a bullet style or warpspeed.
When I got my y&b pipes, I asked Jody about the cat & she said that they weld them on. Unless they have different ones with flanges now.
i just bought one from WS but didnt open the box yet. didnt hear bout the gasket problem you stated. is this just you or everyone? should i just resue the ones on my car right now? any suggestions would be great
Don't reuse your gaskets....
Get the metal ones from Nissan.
knight_yyz
Nov 1, 2015 01:34 PM
atriuum
Sep 28, 2015 01:19 PM
