code 400 egr..........
Old Jul 12, 2007 | 08:10 PM
  #41
max ride 41's Avatar
Originally Posted by supermanphil
It is possable to clean tube. with a little time and like i said carb cleaner, tube will be clean. Sorry also forgot to add that you need to pic to break the big parts loose. But like I said no parts are needed, maybe some gaskets but no tubes. $10 tops. I have done about 20 of these and never have i had to replace the tube, even in the worst conditions. And I've seen them all!!!
good for you, not everybody has the knowledge to do that job. and, you do need a cleaner to put the egr tube in to soak and loosen the old carbon deposits that have hardened into the tube itself. otherwise, if you just try scraping it out with tools and brushes you risk having some metal get into your block that may still be in the tube. i just replaced it, brand new oem item, 20.00 and worth the peice of mind.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
