Finally did my knock sensor
Old Apr 5, 2007 | 01:17 PM
bhunter's Avatar
Wow. It took about 10 minutes and the improvement was instantaneous. I drove it 600 miles over the weekend and my mileage went from 20-21 on the highway to 25.7
Old Apr 5, 2007 | 03:02 PM
goldtooth's Avatar
i have my new KS comming in. What tools and whatnot and advice can you recommend to me to a quick and painless swap?
Old Apr 5, 2007 | 03:44 PM
99BlackMaxMS's Avatar
If its a cali spec...its at major PITA...you need to remove the swirl valve and other emission crap from the 99s.
Old Apr 5, 2007 | 03:55 PM
goldtooth's Avatar
fed spec............
Old Apr 5, 2007 | 06:38 PM
bhunter's Avatar
A 12mm socket, a long extension, a knuckle and ratchet. Also someone with smallish hands to finger tighten the new on going in. Not exactly painless as you will more than likely bugger your hands somewhat. Don't overtighten.
Old Apr 5, 2007 | 07:40 PM
goldtooth's Avatar
thank you sir
Old Apr 5, 2007 | 08:19 PM
headhunt3r's Avatar
I just got my buddy to do mine as well today... I suspected that the KS was bad since I was getting crap low end power, and after he took it out, he called me and told me it was cracked! He replaced it and the car came back from vacation =)
Btw, there were no codes signaling that anything was wrong... I have no idea what will trigger a code if a cracked KS won't do the trick lol..
Old Apr 5, 2007 | 08:44 PM
Is the knock sensor wire usually replaced with the KS?
Old Apr 5, 2007 | 09:21 PM
PLUMMAXSE's Avatar
The KS wire is not usually replaced unless you break it getting the sensor off, like I did. Not a big deal, my wire was brittle and I believe it was $15 to replace. After 100k miles, it needed replacing!!
Old Apr 5, 2007 | 09:53 PM
Where can you go about getting one? Dealership?
Old Apr 5, 2007 | 10:04 PM
NmexMAX's Avatar
dot dot dot ...
Courtesy parts, Pinnacle Nissan, thepartsbin
Old Apr 5, 2007 | 10:25 PM
95 Maxnout's Avatar
I need to get mine replaced as well.Maybe some of that power will come back.
Old Apr 6, 2007 | 01:16 AM
PLUMMAXSE's Avatar
Got my KS off ebay and the wire from the dealer!
Old Apr 6, 2007 | 06:04 AM
buzpuck11's Avatar
Definitely get it on ebay.
Old Apr 6, 2007 | 06:58 AM
bhunter's Avatar
One of the things about the knock sensor geing bad is it will throw a code but will not in itself cause the engine light to come on. Lost power and mileage will be an indicator to look for a code.
Old Apr 6, 2007 | 08:39 AM
Yeah I am aware of the symptoms...and I have a new KS that I recently purchased. I was just wondering if it would be worth the $15 to replace the wire while I am at it.
Old Apr 6, 2007 | 08:51 AM
bhunter's Avatar
It is pretty easy to check continuity. If it doesn't look damaged and checks out then I wouldn't replace it. On the other hand 15 bucks is pretty cheap and if it gives you peace of mind then go ahead...
Old Apr 6, 2007 | 06:53 PM
iDuty's Avatar
Not to sound boring or anything, but after I replaced the KS on my 97 fuel comsumption improved by about 1 mpg, from 26-27 hwy to 27-28 hwy without AC at around 75mph.
Old Apr 14, 2007 | 10:09 PM
99goldmembermax's Avatar
so is it a must to change KS? My light came up?
Old Apr 15, 2007 | 12:02 AM
darklegend06's Avatar
Just did my knock sensor, it was fun!! Well I have small hands so it was easy. After I did a 5spd swap I got the knock sensor code I replaced it, well my old one was definitely out cause it was cracked.
Good luck to whom ever is changing theres.
Old Apr 15, 2007 | 06:28 AM
sky jumper
that's funny. when I changed mine last summer my MPG went from about 30 on the highway with a bad KS, to about 30 with a good one.
Old Apr 15, 2007 | 07:15 AM
If the light went off, you have other codes as well. Check to see what other codes are there first as the KS does not send signal to trip the light.
Old Apr 15, 2007 | 10:28 AM
bhunter's Avatar
It seems everyone's experience with this is somewhat different.
Old Apr 15, 2007 | 04:12 PM
gudfella's Avatar
can someone tell me where is the KS is located at? What do i need to take off to get to it. Thanks.
Old Apr 15, 2007 | 04:24 PM
KsuMax's Avatar
Cheesing away...
http://www.motorvate.ca/mvp.php/507
there ya go
Old Apr 19, 2007 | 07:11 PM
gudfella's Avatar
kool thanks for the info.
Old Apr 20, 2007 | 04:01 PM
Sarah99GXE's Avatar
Maxima Princess
My light came on and the only thing we were told was it had to do with the knock sensor and something about bank 1.
Is bank 1 the area the KS is located or does this imply something else?
Old Apr 20, 2007 | 05:10 PM
Go back and get the 4 numbers that the code reader got you. Bank 1 usually refers to an O2 sensor in the exhaust....could be any number of codes. That code is what set your SES light....NOT the KS code.
Old Apr 21, 2007 | 08:52 AM
I paid approx 300 to have my KS installed, is that reasonable? I have big hands...lol....
Old Apr 21, 2007 | 10:44 AM
Suzie (v)Q's Avatar
Fast & Furry-ous
www.rockauto.com
OE Part # 2206030P00A {Knock Sensor #2206030P00}
$94.79
___
JLD
hayne
Oct 5, 2015 11:53 AM
msellas
Sep 23, 2015 09:16 PM
homeofbacon
Sep 23, 2015 07:17 PM
