O2 sensor 2 BANK - 1
Old Apr 6, 2007 | 10:34 AM
maxworld101
mechanic says that he'll change it for 100 bucks ...i said let me ask some friends first.....
idk which one it is ...i pull the code but it does not give me anything .. but the light is on
i have a cat converter from a 95 or a 96 ..i dont remember ... and the oxygen sensor plug on that cat does not fit into the one on the car....
what to DOOO what to DOOO ?
Old Apr 6, 2007 | 10:52 AM
jxkim's Avatar
100 bucks is standard for most places. which is a ripoff. unless hes including the cost of the o2 sensor as well.
i suggest you buy a oem one from courtesy parts ($120) and either do it yourself or find someone off the forums who will probably do it for lot less. only problem is that theyll need to get under the car whcih is a real *****
Old Apr 6, 2007 | 11:03 AM
maxworld101
so " sensor 2 BANK - 1 " is the one on the CAT ?
Old Apr 6, 2007 | 11:12 AM
Jesse729's Avatar
It's the one in the Y-pipe closest to the firewall. Mine went bad a few days ago im going to look at it shortly and probably replace it my self.
Old Apr 6, 2007 | 11:19 AM
ComradeJew's Avatar
yup, thats the firewall. Buy the sensor yourself and change it yourself - will take you 20 mins.
Old Apr 6, 2007 | 11:45 AM
maxworld101
then how come car doesnt give a code about the one on the CAT ?
Old Apr 6, 2007 | 09:34 PM
maxworld101
no clue?....
Old Apr 6, 2007 | 09:41 PM
MajesticMan's Avatar
O2 Sensor
How many miles is on your ride in the 1st place :
MajesticMan
Old Apr 6, 2007 | 09:51 PM
candyass's Avatar
I just recently got the CEL for the same O2 sensor bank 1 sensor 2. 143,000 miles FWIW
Old Apr 6, 2007 | 09:55 PM
job12345's Avatar
I just replaced the o2 sensor behind the Catylitic converter and completed it in about 1 hour. That's because I have limited mechanical skills and fear of getting underneath the car. It could have taken 5 minutes if I did not have to hammer the sensor free (did not have a breaker bar). I also needed to borrow an oxygen sensor socket (image at: http://www.toolsource.com/OstImages/...ages/67696.jpg) from a friend. The Haynes manual was a great help. I recently purchased an OBD II reader (after the ses light came on) and this lovely tool ($100 at Checker auto parts) allowed me to successfully diagnose the problem.
Bottom line is that if you can turn a socket wrench and jack your car up, then there is no need to go to the dealer for this repair.
PS: I did get ripped off for the part at Pinnacle Nissan (Scottsdale, AZ) for $140 before tax. You may be able to find it ("downstream oxygen sensor") on the internet for about $90.
Old Apr 7, 2007 | 06:07 AM
willard00's Avatar
if youre doing it yourself, do not go and buy a universal O2 sensor. i made that mistake. i mean, once theyre in they work fine...but in order to put them in you have to take the old one out and splice all the wires together and its a real mess and can be a pain in the as$.
as for the mechanic, if hes doing it for $100 including the O2 sensor...ide say thats a good deal. if its the price for the O2 sensor + $100 labor, then forget that. do it yourself.
my03maxima
Jul 28, 2024 07:40 AM
jmlee44
Oct 2, 2022 02:13 PM
hayne
Oct 5, 2015 11:53 AM
