Soft brake pedal feel
Old Apr 6, 2007 | 08:54 PM
nismo-max500's Avatar
Ok here it is...
just replaced front rotors, pads and calipers along with bleeding the brakes. My brakes no longer "stick" as I mentioned in a previous thread. But one issue I do have though is the pedal feels "soft" and there is a longer amount of travel when I push down the brake pedal than before the brake job. As I progressively push the pedal down (say multiple pushes slowing down from speed) the pedal builds up pressure to a somewhat normal feeling. Is there anything other than "bleeding" the brakes that I can check out that would be causing this issue?
Thanks again
Old Apr 6, 2007 | 08:57 PM
2da mizzax's Avatar
air in the line.
Old Apr 6, 2007 | 10:43 PM
Cdg2125's Avatar
bleed them again
Old Apr 6, 2007 | 11:14 PM
MadMaxSE-L's Avatar
Doggah Bite...
Originally Posted by Cdg2125
bleed them again
X 2
10 char
Old Apr 7, 2007 | 09:41 PM
heynow's Avatar
AIR TEH LEIN(S)!
If you're having trouble bleeding them urself, take it to a shop!! I had the same problem! Just bleed all four calipers properly.
Old Apr 7, 2007 | 10:06 PM
Cdg2125's Avatar
haha why would you have shop bleed the brakes? How much simpler could that task be?
Old Apr 8, 2007 | 12:18 AM
ImmaSquashYou's Avatar
you'll be surprised...i bled my bike calipers.....changed to speedbleeders on the bike. So air got into the lines....beld the back brakes fine..n then front, don't even remember how many times i did it and for how long. At that time, it was cheaper for me to pay the dealer to do it than me to keep trying by buying all the brake fluid.
Old Apr 8, 2007 | 03:50 PM
Cdg2125's Avatar
thats your bike. Bleeding brakes is not hard on this car.
Old Apr 8, 2007 | 05:13 PM
the_3d_man's Avatar
It helps if you pump the brake pedal a few times to build up pressure, then open the bleeder (with the pedal down). That way the brake fluid shoots out really fast and carries along smaller bubbles with it. Do that a few times on each wheel. and go in the proper order.
Old Apr 8, 2007 | 05:25 PM
heynow's Avatar
what 3dman said
Old Apr 10, 2007 | 11:28 AM
Shoes's Avatar
If bleeding doesn't fix it, then it's likely the booster's going bad. Mine had that problem, and now it's totally shot.
Old Apr 10, 2007 | 11:53 AM
2da mizzax's Avatar
bad booster = hard pedal.
bad master cylinder = soft pedal that travels all of the way down.
Old Apr 10, 2007 | 12:12 PM
Shoes's Avatar
I'll make a separate post about my brake problems so I don't end up hijacking this thread...
Old Apr 10, 2007 | 12:47 PM
2da mizzax's Avatar
You cant make your own thread yet so you may as well post it here.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
ef9
Sep 10, 2015 10:35 PM
jcvgn
Sep 10, 2015 08:03 PM
