Rear Oxygen Sensor
Old Jul 10, 2001 | 06:16 PM
PeteGT2857's Avatar
Hey
Trouble code 0707.
Points to Rear Oxygen Sensor? Check harnesses right? What would be the troubleshooting process on this? At waht point do i replace the actualy sensor. Could it be something major.
Pete
Old Jul 10, 2001 | 06:41 PM
Daniel B. Martin's Avatar
Read the Sticky
Originally posted by PeteGT2857
Hey
Trouble code 0707.
Pete
There is a wealth of information in the Sticky titled ECU Diagnostic Trouble Codes. Go there and read all about it.
Old Jul 10, 2001 | 06:45 PM
PeteGT2857's Avatar
Re: Read the Sticky
I went there but i'm still not sure. I will do waht it says, to check the wiring and the harnesses. But how hard is it to do that? I've Had an escort GT b4 and It ndidn't have an oxygen sensor. Is it right after my cat? Could i put it on Jack stands and look for it?
thanks I'm just learning about this stuff.
Pete
Old Jul 10, 2001 | 07:14 PM
Re: Re: Read the Sticky
... I will do waht it says, to check the wiring and the harnesses. But how hard is it to do that? ...
This diagnostic work may be successfully performed by the novice home mechanic.
... Is it right after my cat? ...
Yes.
... Could i put it on Jack stands and look for it? ...
Yes.
... I'm just learning about this stuff. ...
You really should have a manual. Chilton and Haynes repair manuals are available. Haynes is the better of the two for most purposes. For a detailed comparison of manuals, see http://vbxmaxima.8m.com/manualcompare.html
Old Jul 10, 2001 | 07:17 PM
levine's Avatar
Re: Read the Sticky
hey i got the same error when i tested to see why my engine light was on, (0707) where do i get the sticky titled ecu diagnostic trouble codes, all i know is that its a rear 02 sensor and when i reset the computer thingy under the gas pedal it did not come back on,
did i fix it or turn it off???
thanks
jesse
Old Jul 10, 2001 | 07:19 PM
PeteGT2857's Avatar
Re: Re: Re: Read the Sticky
Yes.
Yes.
i was going to get the service Tech manual from Nissan on Friday. I firmly believe in owning the manufacturer's manual, even though it's 103 dollars. But hey gotta do it. Couple things more and I'll be done.
1.) What should i look for?
2.) Is it just a screw out kinda thing if needed replaced?
3.) Could it possibly becase by running it hard and needing to cool down?
I'm done I promise Dan, Thanks for the help though
Old Jul 10, 2001 | 07:55 PM
Re: Re: Re: Re: Read the Sticky
i was going to get the service Tech manual from Nissan on Friday. I firmly believe in owning the manufacturer's manual, even though it's 103 dollars. But hey gotta do it. ...
I think you will want Chilton or Haynes in addition to the factory service manual. The aftermarket books have lots of valuable pictures. I have all three books and usually reach for Haynes first.
... 1.) What should i look for?
The heated Oxygen Sensors have two components: a heating element and a sensing element. The heating element may be tested with an ordinary ohmmeter. This test is done with the engine off.
Follow the wires away from the Oxygen Sensor until you find the nearest electrical connector. Disconnect the connector. Viewed with the connector latch at the 12 o'clock position, there are three terminals. They are numbered 1-3, right to left. Be sure to measure the terminals in the connector half which is attached to the Oxygen Sensor, not the one which leads to the Engine Control Unit.
Measure the resistance between terminals 1 and 3.
The factory spec is 2.3-4.3 ohms at 77 degrees Fahrenheit.
Measure the resistance between terminals 1 and 2.
The reading should be infinity (no connection).
Measure the resistance between terminals 2 and 3.
The sensing element of an Oxygen Sensor cannot be tested with an ordinary ohmmeter, but it may be tested with a special-purpose tester or an automotive oscilloscope.
The signal from a healthy sensor varies from a low threshold (around 0.2 volts) to a high threshold (around 0.8 volts), and it sweeps back and forth between those extremes about 10 times per second. If a scope trace shows the Oxygen Sensor signal failing to reach either extreme, or oscillating between them at a frequency slower than 10 cycles per second, that is evidence of a "tired" sensor. If your voltmeter is one of the fancy models (Fluke 87, etc.) you may be able to use it in lieu of a scope to make this evaluation.
I've read that a bad Oxygen Sensor can sometimes be rejuvenated by removing it, clamping it in a vise, and heating the sensing tip red hot with a propane torch. This is said to burn off a crust of deposits which interfere with its operation. I've never tried this torch trick myself, so cannot vouch for it's effectiveness. If you have a sensor which is already dead, you have little to lose.
For more information about Oxygen Sensors see:
http://www.volksparts.com/o2sensors.htm
http://members.aol.com/carleyware/library/o2sensor.htm
... 2.) Is it just a screw out kinda thing if needed replaced?
Yes. That's a simplified view, but yes.
... 3.) Could it possibly becase by running it hard and needing to cool down?
Not likely. An Oxygen Sensor may fail to high mileage or being "poisoned" by exposure to various substances including leaded fuels, anti-freeze, anti-seize, RTV sealants, and the residue of burned engine oil.
Old Jul 10, 2001 | 08:15 PM
Originally posted by levine
... where do i get the sticky titled ecu diagnostic trouble codes ...
Sticky is the name for the posts which remain at the top of the forum contents page. The Subject line is prefaced with "Sticky:".
...when i reset the computer thingy under the gas pedal it did not come back on,
did i fix it or turn it off??? ...
The computer thingy is called Engine Control Module. It is located to the right of the gas pedal, not under it.
You turned the Check Engine Light off. You didn't fix anything. If there is something really wrong with that Oxygen Sensor the CEL will come back sooner or later. Probably sooner.
Huttig2009
Sep 25, 2015 03:31 PM
iflexsteel
Sep 15, 2015 03:37 AM
Maxilano
Aug 31, 2015 07:33 PM
doobadoo
Aug 15, 2015 06:43 PM
