Changing the Oil Pan Drain Plug Washer?
Old Apr 15, 2007 | 07:20 AM
maxima_million's Avatar
Ok, I've been changing the oil/filter in my cars for years. Recently when I whent to buy OEM oil filters (the only way to go!!) they spoke about changing the Oil Pan Drain Plug Washer as well and that it should be done every 7,000 miles.
I can honestly say that this was the first time I've ever heard of the item let alone changing it! Is this true? My '98 SE with 125K doesn't drip a drop of anything (knock on wood) . I am religious about changing trans fluid, break fluid, steering fluid etc.
I ended up buying them since they were < $1 each. I'm starting to think I'm going to be keeping them in the box with the supplies and forgetting I have them.
Sooo, has anyone ever changed one? I'm assuming it acts like a sleeve for the oil pan bolt and that you take it out with a wrench and replace it the same way?
Thanks!
Old Apr 15, 2007 | 07:25 AM
2da mizzax's Avatar
does not need to be touched unless the drain plug starts leaking.
Old Apr 15, 2007 | 07:35 AM
ok, I was hoping to hear something like that! Thanks for the reply!
Old Apr 15, 2007 | 07:48 AM
JwaxMax99's Avatar
http://forums.maxima.org/showthread.php?t=230184
Old Apr 15, 2007 | 08:14 AM
2da mizzax's Avatar
http://forums.maxima.org/showpost.ph...6&postcount=15
another idiot saying something he knows nothing about.
Old Apr 15, 2007 | 08:17 AM
nismology's Avatar
^^Every oil change?
Old Apr 15, 2007 | 08:38 AM
sky jumper
you don't need to change it every oil change, but after about 4 or 5 cycles of torquing to prevent leaks the crush washer will be very difficult to separate from the drain plug - I had to cut mine off. I bought a couple new ones a while back, and the parts guy threw in whole handful for free, so I now change them every time.
Old Apr 15, 2007 | 10:25 AM
bhunter's Avatar
The give them to me with each filter. Little compressable copper rings.
Old Apr 15, 2007 | 12:35 PM
Trajiksmax's Avatar
Proud Maxima Owner
Originally Posted by 2da mizzax
Does not need to be touched unless the drain plug starts leaking.
I replace mine every oil change. They gave me one for every filter I purchased, why not use them.
Old Apr 15, 2007 | 12:39 PM
nismology's Avatar
I haven't experienced a leaking oil plug once, regardless of mileage.
Old Apr 15, 2007 | 05:37 PM
frisballs17's Avatar
I work at jiffy lube, in the lower bay. i change plugs and washers all day. i have seen multiple cars leaking from the plug because of the washer (90% fords). i would recommend getting fiber gaskets if you are really worried about it. they work the best.
Old Apr 15, 2007 | 05:46 PM
2da mizzax's Avatar
He worked at Jiffy Lube. Now we know they never really did the service so how would e know about washers? http://youtube.com/watch?v=wiCAJ8ULnaI
Old Apr 15, 2007 | 06:21 PM
abomb1987's Avatar
thats why i do my own repair work, unless something major i take it to my mechanic which i known for 8 years
Old Apr 15, 2007 | 06:36 PM
first of all, the one i work at doesnt have lifts. second, im the only lower bay tech except for one day. and third im pretty sure i work my *** off there (over 100 cars a day), and do all the services required. i hope you feel pretty good about yourself now, considering you just dissed a 18 year old kid trying to pay for college single-handedly. way to go
Old Apr 15, 2007 | 07:38 PM
konak85's Avatar
i replace mine every few oil changes
kjlouis
Oct 3, 2015 05:29 AM
97_GXE
20
Sep 17, 2015 08:12 PM
markevans999
Sep 10, 2015 04:29 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
