Replacing Seat Belts
Old Apr 15, 2007 | 08:38 AM
hobokenkid's Avatar
Anyone ever replaced the seat belts? Found a pair for under 100 . Just cannot find anything on replacing them. thanks
1999 maxima
Old Apr 16, 2007 | 05:49 PM
Sounbwoy's Avatar
Unless the car's been in a serious accident, there really should be no need to replace them.
Old Apr 16, 2007 | 08:39 PM
TunerMaxima3000's Avatar
also dont see them goin bad, but they're SIMPLE to replace. just pull the panels in the car and swap em out, little common sense is all you need.
Old Apr 16, 2007 | 08:59 PM
andrei3333's Avatar
Unlimited warranty on seat belts unless u cut them urself (which makes it UR fault) the dealer will replace all WORN seat belts free of charge
somehow when i bought my car it came with the manual AND the original warranty booklet
Old Apr 17, 2007 | 09:17 PM
Sounbwoy's Avatar
Well. It's not THAT easy, b/c IIRC, one or a part of those trim panels (B-pillar) is a once piece fitting. In other words, the belt goes thru it and there's no slot to slide the belt out. So you either have to cut the belt or cut the trim panel.
Old Apr 18, 2007 | 04:11 PM
Dark_man_x's Avatar
na man the b-pillar comes apart in two peaces, bottom and top you have to squeeze the seat belt adjuster thing at the top and pry off the little panel thing on it then you can use a socket to undo the bolt then the belt will come out with no problems.
Old Apr 18, 2007 | 06:21 PM
Sounbwoy's Avatar
Ok. Foggy memory....I had to take the interior apart when I was rebuilding the sunroof mechanism. It was real hot and I didn't have any beer!!!
Old Apr 18, 2007 | 08:03 PM
tsi6001
Oct 3, 2022 10:23 PM
PH98I30
19
Jun 13, 2016 02:38 PM
vingodine
45
May 21, 2016 12:46 PM
JMag90
Aug 25, 2015 09:17 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
