rear windows won't work
Old Jul 11, 2001 | 04:56 PM
Cumalot's Avatar
I don't know what's the problem. When I tried to roll down either one of the rear window, it won't roll down. I got nothing. It couldn't be my driver's master control switch because the locks worked fine. It unlocked and locked the rear doors with no problems. Any ideas? Daniel? I even tried the rear controls, they didn't work either. Couldn't be a fuse problem, could it? I don't think it could be a fuse problem because if it was, the door locks shouldn't work as well, right?
Old Jul 11, 2001 | 05:28 PM
Vyrus's Avatar
RE: Rear Window Jam...
It actually could be a short circuit (fuse), because the door locks have a seperate fuse (also used with keyless entry). I would take it to a garage and replace all the fuses (its not too much moeny anywayz). Just trying to help.
Old Jul 11, 2001 | 07:11 PM
Daniel B. Martin's Avatar
Originally posted by Cumalot
... It couldn't be my driver's master control switch because the locks worked fine. ...
I don't agree with this logic. I'm not saying your problem is the master control switch, but I don't agree with your reason for absolving it.
Do the rear windows operate normally in response to the individual switches located in each door? If so, you know the fuse is good and the window motor is good.
Old Jul 11, 2001 | 08:22 PM
WaarrEagle's Avatar
You don't have them locked do you? Does the front window work?
Old Jul 11, 2001 | 09:14 PM
Cumalot's Avatar
Locked? Of course not. And the front windows do work.
Old Jul 11, 2001 | 09:19 PM
Cumalot's Avatar
No. Like I said in my post, I already tried that.
Old Jul 12, 2001 | 01:47 AM
max808's Avatar
Relay?
Maybe the relay?
Old Jul 14, 2001 | 12:34 PM
Cumalot's Avatar
I got my car back from the dealer. Turns out, I was partially right. The rear passenger side switch is broken; need a whole new switch. The rear driver side problem is a bad wire, that need to be replaced as well. The parts needed to be order though, they didn't have the parts in stock. Dealer said the parts aren't not cover under the extended warranty. Oh well. At least, I asked.
Old Jul 14, 2001 | 01:15 PM
Newman's Avatar
how convenient that BOTH units needed to be REPLACED and it isnt covered by warranty. stay away from the dealer.
Old Jul 14, 2001 | 03:06 PM
max808's Avatar
DIY
If you haven't already done the work, get the part numbers from the dealer and order online. Sound like a job you can do yourself and save some $$$.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
mpbclutch33
Aug 21, 2015 06:09 AM
doctorpullit
Aug 20, 2015 05:15 PM
kjm900r
Aug 5, 2015 07:14 AM
