Brake flush with DOT4 fluid
Old Apr 26, 2007 | 11:13 AM
nitink's Avatar
Can I Drain & Fill brake reservoir with DOT4 brake fluid, will it cause any problem with ABS?
Car 95 gle, 109K miles
Old Apr 26, 2007 | 11:31 AM
pmohr's Avatar
No more Maximas...
DOT4 will be fine, anything but DOT5.
Old Apr 26, 2007 | 11:44 AM
TurTLe*'s Avatar
^ what he said..
drain and fill brake fluid... i hope you mean bleed them at each bleeder =P
Old Apr 26, 2007 | 02:33 PM
nitink's Avatar
yes I meant bleed @ each bleeder.
Doesn't abs reservoir contain break fluid, will it behave differently for dot4?
Old Apr 26, 2007 | 02:51 PM
nick_auto96's Avatar
I used Valvoline synthetic brake fluid recently. Works on both Dot 3 and Dot 4 systems. No problems so far.
Old Apr 26, 2007 | 03:01 PM
Matt93SE's Avatar
STFU n00b!
You will be fine. just remember the ABS system holds quite a bit of fluid. you'll need at least a full quart to properly bleed the system. 2qts would be better.
Old Apr 26, 2007 | 06:49 PM
andrei3333's Avatar
Is Dot 3 not available ? i know thats whats required for the 4th gen. But they are most likely equivalent just like dexron II and III is for the tranny.
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
