Few quick questions...
Ok here goes
1) How do you rewire the cornering lights on a 95 to make them bright all the time?
2)How do you remove the back seat? (Not the bottom part that is held in by latches, but the part that you rest your back on)
3)How do you remove the rear deck?
4)What is the regular price of the UPRD ECU if I don't take advantage of the group deal for some strange reason?
Thanks guys...
Thanks guys...
1). Pop out the corner lense. You can do this by opening the hood and unscrewing the screw holding it to the headlamp, then insert a flat head screwdriver in between the corner lamp and the headlight and pop it out. Now, you'll see three wires going to the bulb. Two colored wires and a black ground. Just cut the two colored wires and switch them. Ta-da!
2). Take out the bottom part by unlatching it and just lifting up. Now on the lower right and lower left of the back rest you'll see a 10mm bolt/screw. Just remove that and lift up.
3). Once you have the rear seat out you can just pop out the deck, there are little clippies holding it in.
4). Dunno. 3 out of 4 ain't bad huh?
Chris
Chris
Check this out for the stereo install questions
http://www.geocities.com/artourb/max...hoto_album.htm
1) http://web2.airmail.net/scutchen/max_faq/
Look in the electronics section and then read on.
2) There are bolts on the left and right side of the seats. There are also some bolts hidden in the arm rest, you have to put the arm rest down and remove the flexible fabric piece. There are some bolts behind it, then just lift and the seat pops out real easy.
3) Once the seat is out, I recommend removing one side of the upper plastic behind the seats (this makes it much easier) The rear deck is held in by multiple push through clips (bright orange in my car) and the insulation attached to the rear deck sticks to the metal frame in the back.
4) I think that it's around $475 without the 20 people.
Hmmm >>
Why do this? All it does is to annoy and distract other drivers. There's a reason why Nissan killed the cornering lamp feature in '97.
Re: Hmmm >>
You can rewire the lights to use the brighter settings all the time. But also, Polarg make a superwhite dual filament 5W/22W bulb, so if you rewire the lights, they are brighter but not too bright.
My friends 95 GLE, his corner lights go brighter when he puts on his turn signal, and it makes it much easier to see, it allows a wider field of vision.
I'm rewiring my corner lights and getting the Polarg bulbs for looks (they are superwhite to match my PIAAs) and it also improves your vision along the side of the car. I noticed this when going on a wide on-ramp, my friends car let you see everything through out the turn, whereas in my car you can't see that good.
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
