wd-40 works on the antenna?
Old May 2, 2007 | 06:23 PM
blimblam's Avatar
the antenna on my max is kinda dry and needs to keep it moving. it wont go down all the way, so should i use wd-40 on it to get it moving again?
Old May 2, 2007 | 06:24 PM
kcryan's Avatar
wd-40 will work fine, keep her lubed up
Old May 2, 2007 | 06:56 PM
NmexMAX's Avatar
dot dot dot ...
A dry lubricant would work better for this application. Graphite poweder comes ti mind. Why not jsut get a new unit? Only 27$, and 15 minutes to change.
www.pinnaclenissan.com
Check the How To Stickys to see a write-up.
Old May 2, 2007 | 08:00 PM
KsuMax's Avatar
Cheesing away...
use a silicon lube rather than wd 40
Old May 2, 2007 | 08:03 PM
andrei3333's Avatar
wd40 is black and will make ur antenna look ugly, especially after driving around for a while and it collects dust,. i used something called Rust Check its a spay can that worked perfectly all winter keeping the salt away
Old May 2, 2007 | 08:04 PM
jojo98maxima
WD 40 works fine
Old May 2, 2007 | 08:46 PM
LLZuB's Avatar
i used wd-40..works well....just try and keep it away from the paint...or make sure u wash or wipe it off if it does get on there
Old May 2, 2007 | 09:15 PM
one-via's Avatar
WD 40 works like a charm when my antenna went down 3/4 of the way and got stuck. It's a great cleaner too. I just turned on the radio, sprayed it down, let it soak for a minute or so, and then used a rag to wipe the excess, dirt, grit....antenna's been working fine ever since. That stuff does wonders.
Old May 2, 2007 | 09:19 PM
f550maranello2's Avatar
wd-40 ftw... works great and drives moisture away
Old May 3, 2007 | 04:19 AM
kcryan's Avatar
Since when is wd-40 black?
Old May 3, 2007 | 07:47 AM
winman15's Avatar
sounds good, Iv got the same issue on my '95 gle. Mine just be from some a-hole bending mine...
Old May 3, 2007 | 09:15 AM
maximafrenzy's Avatar
Fuhget About It.....
I use it and it hasnt turned mine black, just spray a rag lightly and wipe I do it all the time.
Old May 3, 2007 | 04:01 PM
killerVQ30DE's Avatar
I also used engine degreaser to remove all the old oil and crap that was on the aeiral and making it get stuck on the way up & down.
Old May 3, 2007 | 06:12 PM
kris3983's Avatar
i have been useing wd40 on my antena for years
never had any probles
Old May 3, 2007 | 07:20 PM
blimblam's Avatar
wd-40 it is until i get a better suggestion. thanks.
Old May 3, 2007 | 08:36 PM
mystican's Avatar
Anti-seize works well too!
Old May 3, 2007 | 08:45 PM
maximacruizer's Avatar
the stuff i think he was talkin about that will turn black is the Graphite power.. its a mess
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
