ksport clunking noise....
Old May 6, 2007 | 06:03 PM
kaptainkrunk's Avatar
Hi all,
I had my ksports for around 2 years with no noise issues, but now the driverside front coilover is making clunking noises. Anyone have this problem or a possible solution....really hope i didnt blow the coilover
Old May 6, 2007 | 06:44 PM
Fr33way™'s Avatar
Wild for Width
Check the pillow-ball mount for play.
Old May 6, 2007 | 06:45 PM
Fr33way™'s Avatar
Wild for Width
Millie Miliga 16x17.5 Evo 5 w/ 225x50 BFGoodRich Traction TA's
Those are WIDE wheels by the way.
Old May 6, 2007 | 08:31 PM
haha i was meaning to change that. Whats the best way to check the pillow mount?
Old May 6, 2007 | 08:35 PM
Fr33way™'s Avatar
Wild for Width
Pop the hood and bounce on the radiator support. See if there is any noise. If there is check the area.
Old May 6, 2007 | 08:36 PM
Fr33way™'s Avatar
Wild for Width
It can also be several items not tightened to spec or preload (or lack of) on the spring.
Old May 6, 2007 | 08:47 PM
This problem occurs when i go over bumpy sections of road, i thought it was the tie rod ends/balljoints but i replaced those and still clunking. I will give it a shot tomm after work to see it is the problem. Thanks.
Old May 6, 2007 | 08:53 PM
shiftnatredline's Avatar
Godzilla
The strut mounts have probably just taken a crap.
Old May 7, 2007 | 08:38 PM
I see some oil when I investigated under the dust boot....i think i blew the strut, do you guys know who in the forum can hook up a pair of front struts preferable a little less stiff than the standard spring rate they come in for the maxima?
Old May 7, 2007 | 09:12 PM
maxima985spd
im 200% sure your KSport shock is blown. good luck getting a replacement without paying. a new shock will be around $130 shipped and will blow in another year.
Old May 7, 2007 | 09:43 PM
sounds like you have experince with this....you think i should switch to another brand?
Old May 8, 2007 | 08:11 AM
Fr33way™'s Avatar
Wild for Width
In the GD section Mike can get specific rates on D2s. I would be suprised if they were significantly different.
Old May 8, 2007 | 09:23 AM
maxima985spd
Yes, I have experience with this. I've had KSports for almost two years. The only problem with them is that the shocks do blow. But that is common on any coilover kit. So you either keep your stock suspension or suck it up. I really like KSports i just think the warranty should be longer.
Old May 8, 2007 | 11:00 AM
Fr33way™'s Avatar
Wild for Width
That is not true. There are people with JIC's/Basics for 5-6 years now.
Old May 8, 2007 | 11:09 AM
maxima985spd
yea but rebuilds are pretty much necessary.
Old May 8, 2007 | 12:30 PM
Fr33way™'s Avatar
Wild for Width
Maybe in CT.
Old May 8, 2007 | 02:34 PM
maxima985spd
hehehehehe
Unclejunebug
Apr 2, 2016 05:42 AM
msellas
Sep 23, 2015 09:16 PM
ColdCananda
Sep 20, 2015 10:45 PM
