Changing guage bulbs
Old May 9, 2007 | 03:35 PM
Blackmax1924's Avatar
I know you're all going to say search and look for it yourself, but I have and now I have a few questions about it.
Well I have already changed the bulbs behind the guages once before to green, i used the standard 194 bulbs. After maybe half a year some of them have lost the green color, so some are a yellowish color and some are green. I was just curious about what other people have used for bulbs/leds to change the color of the guages.
So if you could please tell me:
what you are using for bulbs/leds?
Where you got them?
Stephen
Old May 9, 2007 | 07:06 PM
lilaclucymaxima's Avatar
Team Ramrod
Where you got them?
Stephen
I have replaced mine probably about 5 times. I've used the regular blue bulbs before, but they turned green. Then I switched to LED's. If you go LED's, which I prefer... use a bulb with many LED's in it, for brightness purposes. Here's an example http://cgi.ebay.com/ebaymotors/New-1...24085539QQrdZ1
Old May 9, 2007 | 07:48 PM
black_maxed95's Avatar
i just did mine to red leds this last weekend. i just replaced each bulb with a led and resistor soldered. then i also added an extra led/resistor right behind each needle. its a little dim though. part of it is just because i chose red where as white or blue would be brighter.
Old May 9, 2007 | 10:00 PM
jxkim's Avatar
i did mine red. bought from superbrightleds.com
they have led bulbs in the 194 size. ebay is a ripoff for these led bulbs. i went with the 5led form because wanted as much light spread. dont go for straight out brightness for itll cause hotspots, but if you look on their site you can see the 5-led is widest and spreads the most light out
Old May 10, 2007 | 07:57 PM
wirelessdude04's Avatar
gonna swap out the bulbs in the near future. Thread is very helpful... Thanks guys
Sir Tilus
Mar 22, 2016 01:49 PM
JoshG
51
Sep 21, 2015 10:41 PM
meccanj98
Sep 16, 2015 06:06 PM
minsbang
Sep 11, 2015 08:48 PM
