Burning smell, some white smoke from under the hood
Old May 12, 2007 | 10:33 AM
vnphantom's Avatar
AC Compressor motor is slipping ... Belt loose? (Photo uploaded)
I'm kinda a noob when it comes to car. But ...
When I was driving down an express way, about 50 - 55 mph, I noticed a burning smell from the AC vent. Then, about 10 seconds later, I see little white smoke coming up from under the hood. Panicked, I pulled over.
Here's the scene. I see little white smoke rising from under the motor belt, to the left of the hood. I have not had this problem ever before. I'm still smelling the burning smell, but not smoke ... Should I replace the belt, and probably oil change?
How much would it cost to replace the belt? It's kinda hot here in DC lately and I think something might be burning soon. Should I continue driving it or should I have it look at first?
Help or advice is much appreciated.
Old May 12, 2007 | 10:38 AM
CaptainFill's Avatar
What were your driving conditions? Really hot? Long drive? Where was the engine temp at?
Old May 12, 2007 | 10:45 AM
vnphantom's Avatar
I was driving for about an hour at around 60 - 70 mph ... The engine's temperature was right at the middle of H and C ... (Is that what you are concerned about?)
Old May 14, 2007 | 08:48 PM
vnphantom's Avatar
Ok, I know what the problem is ... how can I fix it.
It seems that when the belt rotate, what looks like my AC compressor does not move. Or rather, it keeps slipping ... Lose belt? How can I adjust a lose belt? ...
The round motor on the image is the one that is slipping. Picture is taken from under ... Any idea?
Old May 14, 2007 | 09:06 PM
vnphantom's Avatar
Actually, is the AC compressor supposed to be rotating even when it is not engaged? ...
Old May 14, 2007 | 09:09 PM
KRRZ350's Avatar
I'd remove the belt and make sure the compressor spins freely by hand first. you have more than a loose belt going on...... Read the stickys or fsm for belt adjustment info, Hint: you will need a 14mm wrench and socket.
Old May 14, 2007 | 09:11 PM
KRRZ350's Avatar
yes, the clutch assembly (pulley + triangular looking thing) should always be rotating, but the actual a/c compressor does not always rotate. Does the pulley not rotate with the engine running? In the maintenance faq you will find instructions for replacing the bearing
vnphantom's Avatar
Still append to the question, the motor on the image, the one that's in focus, closest ... Is it the AC compressor? I read the Haynes Manual and they said it's the AC compressor ... If it is, is it supposed to spin all the time, together with the belt?
Old May 14, 2007 | 09:13 PM
KRRZ350's Avatar
yes, that's it, and we both kept responding to quickly, yes, it should always be rotating with the belt
Old May 14, 2007 | 09:17 PM
vnphantom's Avatar
Thanks KRRZ350 ... the pulley is rotating ... just the AC compressor motor slips ... I mean, it looks like it's rotating but very very slowly ... Agg ... I will post video if that helps ... ^^ Anyway, I'm taking a bus tomorrow to work. Lolz ... don't have time to work on it till Wednesday.
Old May 14, 2007 | 11:28 PM
Jellyfishian's Avatar
Difficult is NOT impossible!
Sorry if I missed something, but when the the A/C compressor is not engauged (not on) the triangular thing will be stopped, and the belt will still rotate around it. When you turn the A/C on the trinagle thing moves with the belt.
Hope that helps
Old May 15, 2007 | 05:55 AM
vnphantom's Avatar
Uhm ... jellyfishian ... if that's the case ... with that many friction ... should it starts to burn the belt out? ... Cuz I was smelling something burning under there, and it sure smells like rubber burning ...
Old May 15, 2007 | 09:00 AM
There is a ring that rotates around the A/C compressor when its not on so the belt still spins freely.. If that is locked up on your car I would assume the belt would be torn up very quickly.. Here is what the compressor should look like: http://media.putfile.com/ac-compressor-fixed about half way through the video the compressor engages.
Old May 15, 2007 | 10:34 AM
DomoMaxima98's Avatar
Man i gotta read this im in DC/VA too and its startin to get warm out here...
Old May 15, 2007 | 11:16 AM
vnphantom's Avatar
Uhm ... jellyfishian ... My AC compressor does not stay still before it's engaged like that in the video ... Rather, it kinda spins slowly now and then ... looks like it's slipping. This happen when the AC is not on. I'm gonna run home after work and see what happen when I engaged the AC compressor. Probably, I'll post video too.
Thanks man
Old May 15, 2007 | 08:23 PM
vnphantom's Avatar
Update on the Original problem:
I got 2 burnt fuses ... One is for the AC that's 7.5 and one is for the Fog Light 15 (No wonder why my fog lights haven't been working .... duh) Fusible Link box next to the battery ...
But still, how does that contribute to burning smell from under the serpentine belt .... I still can't figure it out ....
Fbana41
Aug 29, 2016 12:18 PM
BobTX10
Oct 7, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
