tire size change for 17 inch rims
Old May 13, 2007 | 01:46 PM
aih98max's Avatar
scoobystoned...
on my maxima i have 2003 OEM rims, i believe they are 17x7.5. Currently i have tire size 225/50 R17 on the rims, but i need new tires and i think i am going to go with size 235/45-17 for new tires because that is the size tire rack recommends and that size of tire is cheaper than what i have. what are the pros/cons of changing to this tire size??? will i have more wheel gap (my car is on hp's and h-techs, soon to be illumnia's and h-techs)??? thanks
Old May 13, 2007 | 03:01 PM
Dark99GLE's Avatar
you'll have more wheel gap, but the tires and wheels will be the correct size for the speedo readout
Old May 13, 2007 | 03:26 PM
imported_Jonny_Black's Avatar
yes..the wheel gap will be a whopping 1/4 of an inch larger...do to the fact that a 225/50 has an overall diameter of 25.9" and the 235/45 has a OD of 25.5" give or take on manufacture. I realize that might be excessive for some people...but I think I would risk it.
Old May 14, 2007 | 05:14 AM
phenryiv1's Avatar
Mod her. Ate her.
You lose some comfort with a 235/45 v a 225/50. I always found that the 225/50 was cheaper than the 235/45.
I hated the 235/45. The last set that i had (on a 5th gen) was a pain. I'd have rather gone back to the 225/50.
That is just my experience, however.
Old May 14, 2007 | 05:22 AM
samito's Avatar
over all tire diameter is the same between the two sizes---235/45 are a little wider
Old May 14, 2007 | 09:05 AM
pmi3096's Avatar
a 235 is 10mm wider than 225. But you lose sidewall. I say just go with the 225. Yea i down grade from a 225/45/17 to a 215/55/16 and took the comfort over the performance.
Old May 14, 2007 | 09:34 AM
NmexMAX's Avatar
dot dot dot ...
Just to clarify, the OEM size is 17.7"
Old May 14, 2007 | 01:55 PM
aih98max's Avatar
scoobystoned...
I am almost 100% sure I am going to go with the 235/45-17's now because they are cheaper. I think I am going to get Fuzion HRi's to replace my Kuhmo KH11's. Does anybody have anything to say about Fuzion HRi tires??
Old May 14, 2007 | 11:28 PM
96blkonblkse's Avatar
some people will say 235 are too wide for 17x7. Honestly, id probably stick with 225/50/17. Check out the hankook ventus es v4 105. cheap and are pretty sweet tires, nice tread pattern, good grip in dry/wet/snow. Havent really pushed them, but compared to the stock dying re92's they are 100000000x better. I have these on my 02 se, and it made a huge improvement.
Old May 15, 2007 | 06:29 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread....25#post1176625
http://forums.maxima.org/showthread....78#post1503478
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
maximaham
Aug 20, 2015 10:23 AM
RealityCheck
Aug 5, 2015 06:18 AM
