Question on struts
Old May 17, 2007 | 01:33 PM
maximized98's Avatar
Addicted to the Org
Question on struts
I am just about ready to order some struts and springs. I'm going to go down 2 inches, and i was wondering two things. One, are any struts going to have a warranty with a 2inch drop? Also, say i get the hp's, how long can i expect for these to last on a 2inch drop? Don't want to spend an arm and a leg on struts if they will go out fairly quick.
Old May 17, 2007 | 01:45 PM
hectorc's Avatar
Upper Midwest Wheel Whore
You will need to spend and arm and a leg to get struts that handle a 2 inch drop. If you think the HP are expensive...I suggest to keep saving more money then. Also HP's are only designed to take a midly drop if any. You will need Illuminas so start saving.
Old May 17, 2007 | 01:49 PM
96DentKING's Avatar
http://www.shox.com/appguide/shoxshop/productsdisplay.php<-----Best price on a full set of Illuminas that I could find. 442.00 I think..
Old May 17, 2007 | 02:02 PM
Addicted to the Org
I was using them as an example, there is no need in me spending 400-500 dollars on some struts that will die on me within a couple years or so. Just courious how long these aftermarket struts can handle that amount of drop
Old May 17, 2007 | 02:37 PM
97SEdriver's Avatar
this place is dead
KYB's still have lifetime warranties
Old May 17, 2007 | 02:48 PM
felix's Avatar
Sittin' On Chrome
Yeah, but the GR2's are only under warranty with a 1.5" drop or less.
Old May 17, 2007 | 03:57 PM
vilmaxima's Avatar
I got a set of Eiback pro-kit about 1.5 inch drop with Tokico Illuminas. I have had them for about 2 years now and its working fine street/city driving.
Not too bumpy at all. (with the illuminas u can always adjust also)
Old May 19, 2007 | 10:06 AM
Addicted to the Org
So it's safe to say that if i want my struts to last, i need to only drop it 1.5?
Old May 19, 2007 | 10:12 AM
Cdg2125's Avatar
If you're going for a 2" drop or more you should be getting coilovers. Not struts and springs. HP's with a 2" drop will not last long. This is all covered in the suspension stickies.
Old May 21, 2007 | 04:16 AM
97SEdriver's Avatar
this place is dead
My issue with coilovers is the amount people are having to rebuild the dampers. Even JiC suggests to rebuild them every 1.5-2 years, I no longer have that kind of time or patience.
Old May 21, 2007 | 10:19 AM
phenryiv1's Avatar
Mod her. Ate her.
It is not only the drop- it is also the spring rate that blows struts.
Old May 27, 2007 | 10:39 AM
vilmaxima's Avatar
I got the 1.5" drop cause I know the roads around here wouldnt go well with a 2" drop it would be way too bumpy and uncomfortable. So I guess it also depends on where u will be driving it.
Old May 28, 2007 | 11:33 AM
Peebs187's Avatar
You would hardly notice the differece between a 1.5" or 2" drop side by side. My vote goes to saving yourself a lot more time for driving rather than fixing...
matts95max
Apr 23, 2025 10:44 AM
dvcamp
Sep 18, 2015 10:17 AM
Stagnet04
Sep 14, 2015 11:28 PM
Johnny9595
Sep 3, 2015 05:18 AM
