firewall question
Got some good advice from studman.
"I ended up getting the wire through the same hole as the hood release cable...I stuck a screwdriver through the rubber boot/grommet from under the dash, duct taped the wire to the screwdriver, and pulled the wire through from inside the fender well."
That is the most common. If you need another hole the best thing you can do is drill one in that same location. Start with a small drill bit for metal and gradually use bigger bits to suit the size you want.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
