finished interior lighting (pics)
Originally Posted by mendon99
http://cgi.ebay.com/1N4007-Diodes-1-...QQcmdZViewItem
^ these will be fine. if you solder them on to the positive side of the LED, the silver line on the diode must be closest to where you soldered, or vice versa if you put them on the neg...
confused yet?
PM me when you get to ready to do this and ill draw you a diagram.
confused yet?
Originally Posted by maxprivate
mendon so you are actually soldering a diode and the resistor in series with the positive side of the led? and each led needs one correct?
It doesn't have to be on the LED itself (if you cant fit it), just on the line its getting power/ground from.
There should be a min and max amp rating on the LED package. Measure your car's typical system voltage while it is running. See if the voltage goes up at higher RPM's. Take the highest voltage reading and divide by the LED's maximun current/amp rating to the the resistor size in Ohms. Your LED's will last indefinately with the right resistor.
unless you add a regulator, correct. with a regulator you could use only 1 for them all, but since you get so many diodes when you buy from ebay, you might as well skip the reg and put one on each.
Slamrod
Apr 10, 2016 05:24 PM
rbaker100
Aug 28, 2015 08:11 PM
