benefits of midpipe
Old May 23, 2007 | 03:07 PM
mge2790's Avatar
benefits of midpipe
are there any real benefits to adding a mid pipe to an intake system? does it improve/make louder the sound of the intake or does it increase the efficiency at all? or is the only real benfit asthetics?
Old May 23, 2007 | 04:03 PM
1FSTMAX's Avatar
just makes the intake louder... oh and it adds a few peak hp.. but you loose midrange..
Old May 23, 2007 | 04:44 PM
mge2790's Avatar
in anyones opinion is it worth installing?
Old May 23, 2007 | 04:54 PM
bigpulve+'s Avatar
Dont do it. The stock resonator is very well made. it smooths out the RPM curve and is just better.
Old May 23, 2007 | 05:59 PM
mge2790's Avatar
yeah thats what i have heard, i just wanted to added sound truthfully, other ways to achieve this?
Old May 23, 2007 | 06:24 PM
1FSTMAX's Avatar
if you're installing a mid pipe just because of sound.. then you my fellow org memeber are a ricer..
Old May 23, 2007 | 10:27 PM
Godson's Avatar
Lol^^.....well from experiance I installed my intake with the stock resonator initially and was very pleased,and power was still very smooth,tried it for the past few weeks with the midpipe and while its a whole lot louder I didnt notice any benefit from it but did feel what seems like less midrange smoothness. I dont have dynos nor have i seen any but from my butt dyno it seems "less smooth". End result for me...Im putting the resonator back on./
Old May 24, 2007 | 05:27 AM
3 point slow's Avatar
Ok. major newbie question and Im gritting my teeth just asking this but here goes; Can somebody explain this "mid pipe" on an intake? I know what an intake is, I have an Injen that my car came with. Its the filter then the tube that runs up to the TB. Is that tube the mid pipe? How does that affect mid range power?
Old May 24, 2007 | 06:09 AM
sonicrunch's Avatar
It's a pipe that replaces that box shaped section behind the MAF.
Old May 24, 2007 | 06:46 AM
maximized98's Avatar
Addicted to the Org
i hate to ask a stupid question, but i have a pr style cai, and was wanting to put my stock midpipe back on and can't figure it out. The holes dont match up for the resinator to the back of the maf. What size coupling would i need? I'm thinking some sort of reducer.
Old May 24, 2007 | 07:35 AM
99grnmaxgxe's Avatar
The car sounds loud enough with just a cone filter attached to the MAF sensor. It's been dyno proven that the stock midpipe is better in the low end power range.
Old May 24, 2007 | 08:07 AM
TurTLe*'s Avatar
just install the lower CAI intake part to your stock stuff and be good with it.
Old May 24, 2007 | 08:14 AM
Addicted to the Org
When i took everything out to instal the cai, i think i might have lost a coupler. Because the resinator will not bolt back up to the maf!! dunno
Old May 24, 2007 | 02:29 PM
LTU_max's Avatar
http://forums.maxima.org/showthread....ght=FRANKENCAR
Old May 24, 2007 | 08:12 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
i have a 3rd gen VG30E, and I have been experimenting with that a little this past week or so. I put on a cone filter, and it was good and responsive and smooth, and had a nice purr. I cut my resonator off of my midpipe, plugged the hole, and now I think it was a mistake. It's actually, in my opinion, quieter than having the resonator there on my car, sounds worse, and has no effect on performance. So as soon as i get my hands on another stock midpipe, I'm going to be using that again.
pic of my poor midpipe...
video with stock intake
video with cone filter but with resonator intact
Old May 24, 2007 | 09:43 PM
krismax's Avatar
Father of the 00 VI
i have neither a midpipe aftermarket or the stock my MAF is right on the TB
whats peoples opineon on this?
Old May 25, 2007 | 07:04 AM
That really sucks, you have the shortest intake of all of us! I would try to get a stock midpipe or maybe just buy one off eBay. And where did the 3 vacuum hoses go?
Old May 25, 2007 | 07:15 AM
95bluse's Avatar
I'm surprised your MAF has been shaken to bits by now, they are quite sensitive to harsh vibrations. The accordion section is there for a reason. I accidentally dropped my intake assembly a few years ago and killed the MAF.
Old May 25, 2007 | 08:27 AM
NmexMAX's Avatar
dot dot dot ...
I've already dyno'd this on my A33B. Check the dyno forum.
The MAF sees a tremendous amount of airflow, so, indirectly, timing is retared. My AFR went up a touch (leaner) when I did that. And of course, @ idle, the AFR was very lean due to the PCV breather not being attatched. The MAF 'saw' peak airflow @ 6700 RPM, but peak whp was @ 5900. It did gain ~ 9whp from 6300 - 7000.
Keep in mind, this is using A33B software.
Old May 25, 2007 | 09:04 AM
aznsap's Avatar
just curious, for us 00vi guys, is there a way to use the stock midpipe cleanly? b/c i have an aftermarket midpipe on right now, but the only way i got the stock midpipe to work was using 2 accordian sections and it didn't even fit very well (it was S shaped, b/c the large stock midpipe box hits the ABS stuff).
Old May 25, 2007 | 10:53 AM
krismax's Avatar
Father of the 00 VI
hmmmm maybe the a33 ecu reacts very different because my timing always stays up there.
and the4 time in sig was run with maf like that . so if that hurts my power than my car must be faster than that and also my car doesnt go over the stock 95 max redline . and if its helping i may not see all the benefits that way
Old May 25, 2007 | 12:08 PM
NmexMAX's Avatar
dot dot dot ...
I stated it in theoretical terms, as I don't have any data to prove it. Nonetheless, it will be a small amount. Also, it ahs been proven that the A32 MAF/timing reacts the same way when going in the other direction (taking fuel away = + timing)
Also, I never said it hurt power, take a look in the dyno section, I gained area under the curve throughout.
Old May 25, 2007 | 12:31 PM
Addicted to the Org
So how many people are using the stock midpipe along with the Cai going through the fender. I'm thinking about doing this. Just looks kinda funny though
Old May 25, 2007 | 08:44 PM
Some people are doing this and claim that this is the best setup.
Old May 26, 2007 | 11:37 AM
Cdg2125's Avatar
Since the stock stuff doesn't sit right with the 00vi and the block/pf tb I'm using, I'm having piping made to use the stock midpipe with. Figured it would be solid, paint-able, fewer plastic/rubber connectors and should fit perfect.
Old Jun 7, 2007 | 06:21 PM
Majestic's Avatar
Yahhhhhhh
I've tried many different ways and IMO this is the best way. All the other ways are very one-sided in the power range but this way gives more top end and is also really smooth on the bottom-mid range. I'm not worried about how it looks. Plus you still get the sound of a CAI.
Mahmuth
Aug 16, 2024 08:23 PM
Mahmuth
Sep 25, 2015 10:08 AM
