need help removing transmission
Old May 27, 2007 | 06:56 PM
zx2max's Avatar
I have a 97 5-speed and am removing my transmission. do i have to remove the support bar that goes from shifter to transmission housing. I unbolted both from the trans but the support bar doesn't move. do i have to unbolt it from the shifter side as well?
Old May 27, 2007 | 07:11 PM
zx2max's Avatar
Nevermind I am an idiot. I didn't see the other bolt holding the bracket. Considering this is the biggest repair I've attempted I am doing pretty good so far.
Old May 27, 2007 | 07:17 PM
KRRZ350's Avatar
Figured I'd add in a tip:
If your following the instructions in the fsm, haynes, or chiltons you can save a bunch of time/effort by ignoring the part about removing crossmember, y-pipe, and using a jack to support engine. Instead just unbolt the 4 bolts for the trannsmission mount instead of the one long bolt.
Old Jun 18, 2007 | 10:18 AM
Big EEEE's Avatar
Sounds like good advice to me.
Old Jun 18, 2007 | 10:19 AM
Big EEEE's Avatar
I did the same thing.
James92SE
142
Jan 2, 2024 09:23 AM
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
Socalstillen
Sep 20, 2015 11:46 PM
