For All With Subs
Old May 28, 2007 | 04:41 PM
blimblam's Avatar
For All With Subs
what did you do with your spare tire?
Old May 28, 2007 | 04:49 PM
f550maranello2's Avatar
its in the car hole collecting dust.. i would not be able to use it if i wanted to....
Old May 28, 2007 | 04:55 PM
mendon99's Avatar
tastey wheat
go with 1 sub and the right box and its all you'll need. space saver and i can still access my spare tire just fine..
had to make a new floor though, with hinges to lift the front most portion up.
Old May 28, 2007 | 05:01 PM
midnight0045's Avatar
screw the spare?? haha i picture the spare tire well as a perfect spot for an up-firing subwoofer box
Old May 28, 2007 | 05:19 PM
blimblam's Avatar
i was asking because i'm going to have 2 12" and im afraid i wont be able to use the spare if i need it. so if i have 2 12's, i won't be able to use the spare??
Old May 28, 2007 | 05:33 PM
Wassup2114's Avatar
I have 2 12's and the floor is plenty flexible enough to pull up and reach the spare.
Old May 28, 2007 | 05:49 PM
blimblam's Avatar
its just that my car has like a piece of wood or whatever under the carpet floor before i can get the tire. i'll probably just take that out if possible. thank you for all feedback.
Old May 28, 2007 | 05:57 PM
bigtulley's Avatar
I got one 12 in a big box in the trunk and i can get to mines too. I have to disconnect the wires and pull it out to make sure that I can place everything back in my car once I'm done, but that takes all of 5 minutes.
You might want to go with a bass tube in the car. If you are looking for "hear you a mile down the road sound" then that probably won't be the right speaker to get. I found that you get a little weary of a lot of boom in the trunk after awhile, and you don't even play it that loud as often. Also, with that much boom, the trunk will rattle to high heaven if you don't dynomat or do something along those lines.
If you are not in a show, go with a bass tube IMO. You will have a lot of room left and get a lil' boom to showcase with. I wish I had went that route. I will end up selling my 12 and getting a bass tube. Probably do it this summer. . .
Old May 28, 2007 | 05:58 PM
bigtulley's Avatar
blim,
IMO, don't take that piece of wood out. that is what gives your floor it's rigidity to support whatever you put in the trunk. You can sit your box comfortably on it. I keep mines in the trunk right on top of it and have no probs. . .
Old May 28, 2007 | 06:05 PM
99grnmaxgxe's Avatar
I only had one 12" and had a lot of space.
Old May 28, 2007 | 07:38 PM
KsuMax's Avatar
Cheesing away...
my spare is still in there. If I ever need it I'll just take out my 2 12's to get to the spare.
Old May 28, 2007 | 07:48 PM
MaximaSpd85's Avatar
yes, if you remove that piece of board under the carpet your box may sink into the well....
Old May 28, 2007 | 07:50 PM
andrei3333's Avatar
why not disconnect the wires to the box and lift it out and then take out the spare? im sure everyone can lift a box with two 12's out of a trunk
basically just invest in good speakers and save urself some weight and gas in the process.
i have seen peoples cars get stolen cause they pull up to work banging their base, and thief's nearby sit, wait and listen.
Old May 28, 2007 | 10:22 PM
Jokester66's Avatar
I have 2 12' subs and a custom box, there not alot of room for anything else but you can easily take them out to get to your spare. Just dont Mount the amp/cap on the back of the box. I screwed a peice of wood to the back wall and mounted the amp there. i replaced the stock wood cover, over the spare, with a little more thick plywood.
What subs are u getting?
Old May 29, 2007 | 05:54 AM
blimblam's Avatar
CVR's,,,,10chars
Old May 29, 2007 | 12:47 PM
95MaximaDriver's Avatar
ive got one 12 inch in the back mounted up where the back seat center arm pull down is at and ive still got enough room to get to my spare with no problem
Old May 29, 2007 | 08:51 PM
Algertron's Avatar
still in there, you never know when you are gonna need it
Old May 30, 2007 | 06:14 AM
btmax96's Avatar
Trunks aren't used for keeping spare tires in them, they are for putting subs in them. My spare tire is standing up on the floor behind my drivers seat. You can't even notice it from outside the car. But i guess it had to go somewhere since there is almost a 13 cubic ft. box in my trunk.
Old May 30, 2007 | 08:34 AM
largestal's Avatar
Running 1 12" and have no problems accessing the spare. I did make a new floor out of 1/4 ply just because the OEM was junk.
Redfox
Sep 28, 2015 10:41 AM
Taino14
Sep 24, 2015 02:51 PM
ballerchris510
Sep 23, 2015 08:46 PM
Car Addict
Audio/Video/Electronics
Aug 27, 2015 09:01 AM
