Help! Tie rod or just boot (pic)
Old Jun 17, 2007 | 04:36 PM
AndyGXE95's Avatar
I went for inspection and they failed me for bad left (passenger side?) inner tie rod. I came back and put my car on jack stand. It looks like this:
http://picasaweb.google.com/ppeng777...82269034183154
The driver side is fine.
Since everything is very tight when I try to shake or move the wheel, I think may be only the boot need to be replaced.
What do you guys think? Should I just replace boot or the inner tie rod? I need to do alignment anyway since I will also replace strut bearing. Anyone knows where I can find instructions to replace tie rod or boot?
Old Jun 17, 2007 | 05:55 PM
XJinCT's Avatar
<3's the all motor section
damn man they failed you on just a boot? thats sucks bro. just remove the outer tie rod and unclamp the boot, slide it off, slide the new one on.
Old Jun 17, 2007 | 06:24 PM
AndyGXE95's Avatar
I went to AAA since they are the closest. They wanted $250 for tie rod and alignment!
Thanks for you input bro. Do I need to fill the boot with grease?
Old Jun 17, 2007 | 06:57 PM
edgar_raphael's Avatar
boot kits comes with grease, so yes, you need to grease it.
Old Jun 17, 2007 | 07:14 PM
AndyGXE95's Avatar
I bought this:
http://www.partsamerica.com/ProductD...tNumber=15063D.
It doesn't come with grease. But I have Valvoline DuraBlend Grease. So I will just fill the boot with grease then. I also need to replace my front shock/strut boots. Do I need to grease those too?
user 11122324
42
Jul 18, 2022 03:35 PM
NmexMAX
May 23, 2016 07:38 PM
knight_yyz
Nov 1, 2015 01:34 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
