Need info on RAXELS
http://www.raxles.com/
yip like neal says, marty will hook you up. im still running on mine I got ages ago !!
Originally Posted by protomor
I need some axles too. Well im not sure if I just need the boots or axles, how do you know? Btw, yay first post!
it's easier to just put in a new outer CV joint than just change those plastic boots since there is a chance that dirt and grime got into the exposed components and/or you screw up your joint trying to take it apart to get the new boots fitted on there.
I havent messed much with axles. I didnt know you could just put in a new CV joint and not have to replace the whole axle. If thats true, then why replace the whole axle at all?
Im not even sure my axles are bad. I know the CV boots are torn and dry. I could just take off the axles, put new boots on them and clean stuff up. But if the axles are messed up, I should just get new axles.
BTW sorry for the thread jack. cant really start my own and havent found any posts related to this.
I am currently looking them up on the boards. The free search feature sucks majorly. I might just google the internet instead. Thanks for the info tho. $300 to replace both axles is much cheaper than the local shop that quoted me $1200.
Don't mean to run the issue in the ground, but my experiences with Marty @ Raxles has been absolutely helpful, courteous and really caring/answering questions (even some that would get flamed on this forum
. His product is excellent and he is totally professional and a real pleasure to work with. Many of us have (I have!) experienced REALLY good service from Raxles/Marty, I would recommend any .org'r with CV/axles questions/problems contact him!
Did you guys use the FSM or the Haynes manual to do the axle replacement? which one is more straight forward
I reviewed the haynes manual procedure and have yet to look it up in the FSM.
Originally Posted by KRRZ350
FSM is better on just about everything. Considering you have a '95, and if the axles are virgin good luck getting the passanger side to seperate from the halfshaft bearing, I've found it's usually easier to just remove the 3 14mm bolts from the block and pull the entire bracket instead, it's much easier to seperate after the fact.
Good luck.
Originally Posted by Ricanprez1
$1200 to replace both Axles? Are you kidding me? I paid $250 to replace both at my local mechanic. You would be better off going to Pep Boys or Strauss. I think I was quoted from $400 to $700 for the job.
Good luck.
Good luck.
You sure they didn't just replace the boots? I was quoted 800 for both Axles.
That price is asinine. They must be using OEM axles. You can get parts store axles (like I have always done) for $50 per side...
most people on this board like to say their parts store axle experiences have been horrid, mine have been just fine and I've used them on 3 different maximas, two of them raced heavily and often without issue (knock on wood). I'm going to stick with the cheaper parts store axles until I have reason to switch to more expensive (though still much cheaper than OEM) raxles.
The labor is a few hours for a first timer guy with hand tools. A shop should be able to do it in under two hours.
The whole Axle assembly was replaced. I was there when he did it. $800 bucks is a lot of money for an axle job man. If I was you, I would get those Raxels which people here seem to crave about and install them yourself.
well then there is a certain Goodyear Gemini, that deserves to be burned to the ground...
Burned to the ground? Did you just replace yours at that place? Please say NO.........
Yeah I know from experience myself. When I crashed my 1st 3rd gen, I was forced to drive my mother's Ford Escort. The car altenator died on my way to school and I replaced it and one of those places. I think the charges were close to $400 bucks with labor. I had to, since I was not that close to my house and the towing fee to have it replaced at my mechanic would equal about the same amount.
and ordered a pair from Marty, I'll replace them myself this weekend never done it before but hopefully it isn't a PITA.
Marty is the man, he is the only person i would talk to if my car needs axles again (which it wont because his are already on it) trust me on this one, dont buy autozone or pep boys ones, spend the few extra dollars and get ones that will last. and just replace the whole deal, not only the boots. its worth it
No, I got a quote took a look at it, flipped them off
haha, good one. Good deal you went with Raxles, I thought about getting those when I replaced mine but I didn't have the extra cashola to buy Raxles at the time.Let me know how the install goes.
LoL at
Apr 16, 2020 05:15 AM
fx4five
Oct 1, 2015 04:58 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
