D/S noiseeeee
Old Jul 10, 2007 | 08:25 AM
WhiteA32's Avatar
D/S noiseeeee
With help from a org member we replaced the front d/s and p/s axles. It was fun.....
After a few days of driving I am hearing a new noise...
here is a video
It almost sounds like I am driving on a train track. Its annoying. I am not sure if it is the wheel bearings or not
It happens when I go straight, but when I turn to the left ever so slightly it goes away.
Old Jul 10, 2007 | 12:40 PM
KRRZ350's Avatar
No internet diagnosis is going to help, jack it up, pull the wheels, check the axle nuts are tight, get underneath, wiggle and grab both sides of every joint and check for play. Could be the center bearing on the passanger side halfshaft as well.........
Old Jul 11, 2007 | 02:26 PM
WhiteA32's Avatar
ok when i shook my tire today it moves with the 3-9 and 6-12 position....
Old Jul 11, 2007 | 06:58 PM
WhiteA32's Avatar
i made sure that the lugs are tight, ill check the strut bolts tomorrow
and i got a quote for 380 to get the job done.
Old Jul 11, 2007 | 07:38 PM
f550maranello2's Avatar
its the wheel bearings.....
Old Jul 11, 2007 | 10:15 PM
maxpeed96plat.'s Avatar
Axle nut might be loose or not tight enough, did you use an impact wrench? there could be play in you axle, also are you sure the three bolts on the bracket that hold the long shaft are on tight or is it spinning?
Old Jul 11, 2007 | 10:38 PM
maxima985spd
tighten that axle nut i think thats what we need to do. i don't know why it kept turning and didn't really get tight like the passenger nut.
Old Jul 12, 2007 | 07:47 AM
WhiteA32's Avatar
Ok I was under the car and I had my brother wiggle the wheel. I looked at the axle and it was moving around ever so slightly, not sure if that is suppose to happen...
And the outer edge of my tire is being eaten alive.... on the driver side
Old Jul 12, 2007 | 07:59 AM
maxima985spd
yo swing by tonight we need to fix that ASAP
Old Jul 12, 2007 | 08:33 PM
maxima985spd
yo how do you know when the drivers side axle pops in on an automatic transmission? will the car still drive (move forward) if it's not popped in?
Old Jul 12, 2007 | 10:02 PM
WhiteA32's Avatar
Stealing my thunder
Thanks again man
Old Jul 12, 2007 | 11:40 PM
maxima985spd
i hope the noise doesnt come back.
if anyone else wants to know the axle nut wasn't tight enough.
CMax03
18
Jan 25, 2015 10:29 AM
JsL
Feb 28, 2004 08:45 PM
bg18461
Apr 10, 2002 07:37 AM
