amazing what a $5 PCV valve can do
Old Aug 2, 2007 | 08:13 AM
  #41
heynow's Avatar
Originally Posted by IlyaK
. Every car is slightly different. Glad you got it the way you want it .
lol, getting there
  #42
Flava_24/7's Avatar
Boosted Panda
Ya'll just need to adjust your idle by using that screw on the IACV. 750 is what it should be.
Why not use the idle screw on the actual TB, and then use the IACV to fine tune it if at all needed?
This is how Ive adjusted mine in the past. Just using the IACV adjustment didnt work too well for me.
Old Aug 2, 2007 | 08:37 AM
  #43
IlyaK's Avatar
The Golden One
Where is the one on the TB? I've never noticed it...unless I'm blind.
Old Aug 2, 2007 | 08:45 AM
  #44
KRRZ350's Avatar
Originally Posted by VIP Maxima
i have no idea how because they arent even related.
Asides from the exhaust rattle, allthough I geuss I could see that to, all of your problems were related to the minor vacuum leak your old pcv was causing..........
Old Aug 2, 2007 | 08:47 AM
  #45
KRRZ350's Avatar
Why not use the idle screw on the actual TB?
My favorite reason: Because the fsm says not to.
Old Aug 2, 2007 | 08:57 AM
  #46
IlyaK's Avatar
The Golden One
I hope you weren't taking a subtle stab at me. If you were, I didn't know such a screw existed. Please enlighten me as to where it is.
  #47
heynow's Avatar
which TB screw are we talking about?
Old Aug 2, 2007 | 09:04 AM
  #48
andrei3333's Avatar
i think they all mean the tps adjustment, there ARE no idle asjustment screws on throttle bodies of 4th gens. post a pic if u dare!
Old Aug 2, 2007 | 09:08 AM
  #49
IlyaK's Avatar
The Golden One
That's what I was starting to think because someone mentioned that it makes the throttle better and I know that the TPS does that as I just replaced mine a few months ago. You could do it that way...but I dunno...I find the IACV screw much easier to access and to regulate. But that's just me.
Old Aug 2, 2007 | 09:11 AM
  #50
heynow's Avatar
You mean the two screws that hold the TPS in place? Pics?
Old Aug 2, 2007 | 09:14 AM
  #51
IlyaK's Avatar
The Golden One
Nah...Andruxa was just saying to post pics of the TB screw if there is one because he doesn't believe there is and neither do I. If they are refering to the TPS, then yes. It has the two connectors on top and two little screws...which when you loosen you can "spin" the actual sensor...therefore changing the setting. A symptom of a bad TPS or an unadjusted one is stuff that I experienced when mine died...I had the following:
Gears would "bang" as if the tranny was bad.
I couldn't rev the engine past 3k rpm...otherwise it would cut off and go back down to 1k.
When it started happening...I thought my tranny was toast. It was just a $80 sensor.
Old Aug 2, 2007 | 09:20 AM
  #52
andrei3333's Avatar
yeah thats exactly what i think....
Old Aug 2, 2007 | 09:23 AM
  #53
VIP Maxima
I would imagine that the highway would actually be a better ride then in the city with the modified suspension.
Im on AGX's and Sprints and there pretty stiff, in the city the bumps can get kind of harsh but on the highway its smooth rolling. I dont have coilovers but from what Ive read they ride better then my setup so I would think the ride on the highway would be nice. If not, then the coilovers wouldnt be worth it to me. Makes no since to me to sacrifice that much of the ride just to achieve the slammed look.
Why is the oil catch can a must for a SC setup?
oil catch can is NOT a must to run a s/c but its a MUST if you are concerned with leakage. some members have had leaking blowers and the oil got into TB from what ive read.
as for the slammed look, well the ride in the city is better since the speeds are much lower, your average bump doesnt bounce you around all that much. on highway the handling is top notch but the car is just too low and 35 profile tires dont help the ride quality all that much. i agree that on the highway it CAN be a smooth ride given proper smooth roads but if your doing 85mph and hit a pothole or uneven surface, either you blow a tire/bend your rim or you bounce off the ground and catch air. both of these can easily be avoided in the city @ 35mph
Old Aug 2, 2007 | 09:33 AM
  #54
heynow's Avatar
I think i'll just leave the TPS alone, Ilusha. Don't wanna mess with it.
Old Aug 2, 2007 | 09:44 AM
  #55
IlyaK's Avatar
The Golden One
lol! Ti tozhe slavyan? Ruskiy or ukrainets? Moya sestra zhive v Philadelphiyi.
And I see you're a computer techie, as am I. Nice.
Old Aug 2, 2007 | 09:49 AM
  #56
andrei3333's Avatar
heynow check this out http://forums.maxima.org/showthread.php?t=457497&page=4
Old Aug 2, 2007 | 10:07 AM
  #57
Flava_24/7's Avatar
Boosted Panda
Its actually the stop screw, but its used to adjust the idle.
This is how Ive always been told to adjust the idle,
Default idle speed is set as follows:
Warm up engine to operating temp, Shut the engine off and then disconnect the TPS. Start the engine and set the idle using the default stop screw on the throttle body to approx. ~650 RPMs'. Shut off the engine and reconnect the TPS. Restart the engine and observe the idle speed. If it's too high or too low, adjust the IACV ldle screw until you get the desired idle speed.
I can post a pic this evening when I get home. I have me A32 TB in my shed.Im running a PF TB now so the stop screw is a bit different but does the exact same thing.
Old Aug 2, 2007 | 10:15 AM
  #58
maximus_pr's Avatar
the maxima is a great vehicle to take on long trips, its got amazing hwy ride.
got to agree a few months ago i made a 1008 miles trip and car felt great and it only took like 2 3/4 tanks even when i step on the gas most of the time
Old Aug 2, 2007 | 11:23 AM
  #59
heynow's Avatar
Flava_24/7, it's like a stopper screw for the throttle plate?
Old Aug 2, 2007 | 12:41 PM
  #60
ThurzNite's Avatar
Originally Posted by Kevlo911
Just to add so some of you don't turn this into "seafoam"; THIS WILL NOT FIX ALL YOUR IDLE/HESITATION PROBLEMS, JUST BECAUSE IT WORKED FOR HIM DOESN'T MEAN IT WILL WORK FOR YOU SO DON'T GET YOUR HOPES UP!
Just figured i'd add that so people don't go crazy with "my pcv threads"
Werd. Things I've changed for the heck of it with no noticeable difference:
O2 sensors
fuel filter
knock sensor
pcv
cat
Water Wetter
Jae
Old Aug 2, 2007 | 12:48 PM
  #61
andrei3333's Avatar
so the theory of replacing o2 sensors Without any CEL lights on to improve MPG is not true huh, good i always knew to wait for the CEL to replace any sensors
Old Aug 2, 2007 | 03:17 PM
  #62
heynow's Avatar
he-he-he ROFL
Old Aug 2, 2007 | 11:09 PM
  #63
KRRZ350's Avatar
Lolz, a little paranoid 'eh? I quoted the poster not you, and that was not meant as a stab of any type either
That screw (on the left in that photo) for the throttle stop is calibrated from the factory and allthough it will effect the idle it is not recommended to do so for several reason's, throwing the tps out of the range of proper adjustment is one, same for the iac in theory anyways, and possibly some other ones that I can't explain, I'm tired.
But anyways, since there is a lot of talk and questions about idle adjustment in this thread, ftr...........
Old Aug 2, 2007 | 11:10 PM
  #64
KRRZ350's Avatar
And don't skip the preperation part to "make sure the following parts are in good order", that is KEY, especially #9 as someone else mentioned in this thread about 'before tossing money at it', or maybe that was a different thread, whatever
Old Aug 4, 2007 | 11:27 AM
  #65
Crooper_Hedder's Avatar
60k city miles huh. It just means you haven't used the axles and tires as much. I couldn't imagine not taking my Max on longer trips, it drives so smoothly and the power at speed is great. I guess you just have a show car. Eh, to each his or her own. 172k miles here. Seems to be working fine, although I don't have it dropped or 18" wheels.
Old Aug 4, 2007 | 04:55 PM
  #66
ThurzNite's Avatar
I thought so too, till I drove a friend's Scion tC. Easily accelerates in 5th gear, whereas my 5th gear stinks. Funny, cuz sticker for my car's about the same as my friend's. LOL. Times have changed.
Jae
TKHanson
Nov 24, 2018 01:39 AM
spazma7ik
Jan 12, 2017 09:38 PM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
bumpypickle
Sep 20, 2015 08:22 AM
