Valve Cover!
Valve Cover!
looking for pics of different color valve covers. Looking for paint mine, not sure what color to do, especially because I don't want to paint the lettering!!!
How would you cover the lettering and paint the valve cover itself?
Any suggestions?
Any suggestions?
- I used tape to tape off the black part in the center of the "coil cover," then sprayed it red, then used a model brush and silver to touch up the letters, finishing with clearing the entire piece with nothing taped off for protection.
- The valve cover I sanded, cleaned with degreaser and brake cleaner, then sprayed black and cleared.
Thanks! Yes. I have black and red actually (red calipers, of course also). I am kinda going with a Nismo styling theme.
Hey man, how much would you charge me to do mine? lol
can kind of see the corner in thiis one( and my blue theme going on)
gotta put my 2nd coat on when i get time.. gunna do the letters black and redo the black part to make it look more glossy
also i heard of a way of painting it without getting the letters was to put some lip chapon it and after u spray just wipe the lip chap off and it came out fine
I did mine in a 4 step process
1. primed it then
2. painted the whole thing red (2 light coats)
used painters tape to cover the "red" strip and the "red" nissan letters
(with a razor and patience) then
3. painted whole thing black...
(for the small black letters I used a "paint" marker from a hobby shop) then
4. clear coated
[IMG]
[/IMG]
the valve cover is powder coated
as well as the intake manifold and other parts...
(better than paint IMO)
1. primed it then
4. clear coated
[IMG]
[/IMG]the valve cover is powder coated
The easiest way to paint the coilpack cover with out painting the letters is. get a q-tip and dip it in vasaline and go over the letters.. then spray the whole cover after a couple of hrs... u can wipe off the vasaline..
Originally Posted by Flava_24/7
Painted valve cover with CF coil cover
Originally Posted by JSutter
this has been covered many times. its not rocket science. get some painters tape, paint, and go to town.
JSutter, what's that in your picture above the valve cover?
I notice some guys have the actual valve cover and timing chain cover, and intake manifold chromed or painted. How much work is it to get to these parts? Anyone have tips on painting or chroming, does oil spill out when you take off a timing chain cover? Sorry, noob.
Hey flave what did you use to paint your ac hoses and stuff? i could never get paint to stay on that without cracking out, and is that your amp wire witha fuse on it right above your tranny?
I didnt paint any of my hoses, there taped.
THe wire with the inline fuse is from the High Output 200amp alternator.
Originally Posted by JPMax
masking tape, exacto knife for the lettering
high temp green and clear coat
prep work is 95% of the job
These are not chrome-dipped parts my friend. They are the result of tediously hand polishing the aluminum to a mirror-like finish. The one in the photo below is about 80% finished:
Also made a diamond plate spark plug cover:
