turning rotors?
Old Jul 20, 2001 | 06:07 PM
max808's Avatar
what is the correct way to turn your rotors? thanks.
Old Jul 20, 2001 | 07:07 PM
Eric L.'s Avatar
You can't do it yourself unless you have the proper tools (mainly the lathe).
Take it to a mechanic, and they will have the specs for your rotor to machine it for you.
Old Jul 20, 2001 | 07:29 PM
max808's Avatar
turning and resurfacing?
is turning and resurfacing the same?
Old Jul 20, 2001 | 07:31 PM
Vyrus's Avatar
RE: Turning and Resurfacing...
No, turing and resurfacing are not the same. One is simply turning them round, and one it refinishing it. Eric L. is right, you can't do any at home unless your home is a mechanic garage. Just trying to help .
Old Jul 20, 2001 | 07:33 PM
QikEnuf's Avatar
turning slotted rotors
Can these be turned or just replace?
Old Jul 20, 2001 | 07:37 PM
max808's Avatar
why couldn't you remove the rotor and turn it around yourself and not have a shop do it? wouldn't his make the surface smooth again?
Old Jul 24, 2001 | 03:19 PM
Crazy_T
Did you guys have trouble removing the arm from the rotor? I tried to take the rotor out after changing the pads the the two bolts will not come off.
Old Jul 24, 2001 | 03:42 PM
_DRU_'s Avatar
if im working under the car or close to the ground and i cant get a bolt loose, i use my floorjack. it might be hard to imagine but i just place my ratchet in place where it has to be force upwards to loosen the bolt. then i place my floorjack undr the arm of the ratchet and i start jacking the jack, which is lifting the ratchet, loosening the bolt... know what i mean?
Old Jul 24, 2001 | 04:38 PM
Daniel B. Martin's Avatar
Re: turning and resurfacing?
Turning, cutting, and resurfacing are all equivalent terms. Turning comes from "turning on a lathe", and a lathe is the kind of machine tool used most often for "cutting" the rotor to create new flat parallel surfaces ("resurfacing").
Sometimes a rotor is too badly scored to be resurfaced, or is already too thin from previous resurfacing operations. In that case the only option is replacement. It is important to replace both rotors on an axle at the same time. In other words, if you have one badly scored front rotor you should replace both front rotors. Ditto for the rear rotors.
These are the factory specifications for 4Gen Maxima rotors.
Front rotor, minimum thickness 20mm.
Rear rotor, minimum thickness 8mm.
Front rotor, maximum thickness variation 0.01mm.
Rear rotor, maximum thickness variation 0.02mm.
Old Jul 24, 2001 | 08:06 PM
max808's Avatar
Re: Re: turning and resurfacing?
Thanks! That's exactly what I wanted to know.
Old Jul 25, 2001 | 05:31 AM
goldmax's Avatar
Can a cross-drilled rotor be resurfaced just like the stocker...that is within the factory limitations? Someone had posted earlier on the forum that cross-drilled rotors couldn't be resurfaced. Is that true?
Old Jul 25, 2001 | 08:10 AM
Eric L.'s Avatar
Re: Re: Re: turning and resurfacing?
A few weeks ago I emailed Phuong, who is doing the Eatricezone brake deal, and he said that the cross-drilled rotors can be turned if they warp. If you watch the Edmunds.com review of Porsche Boxster, they said they had those rotors machines to correct a braking problem too. So, it seems that it is possible to machine cross drilled rotors, but I think in most cases since those types tend to warp more than normal rotors, they might warp too much to resurface without cutting the rotors too thin.
Old Jul 25, 2001 | 10:07 AM
QikEnuf's Avatar
Re: Re: Re: Re: turning and resurfacing?
Would this also be the case with slotted rotors?
Old Jul 25, 2001 | 11:06 AM
goldmax's Avatar
Cool...Thanx!
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
Apr 16, 2020 05:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
