Replaced your radiator/heater hoses?
Old Aug 17, 2007 | 03:01 PM
max4evr's Avatar
Have you replaced them because the original ones were old, or sprung a leak?
The rad hoses don't look too hard (and one's a bit crunchy when I squeeze it), but the heater hoses look tougher, so no need to replace them unless they're subject to failure.
Old Aug 17, 2007 | 03:18 PM
matty's Avatar
Mileage on the car ??
Usually its not a huge deal to change the Radiator Hoses and not to expensive either.
Heater hoses usually dont need to be changed.
-matt
Old Aug 18, 2007 | 11:44 AM
1996blackmax's Avatar
Eventhough mine were not bad, I replaced them as my car had some good miles on it. Easy to do, and do not cost that much.
Old Aug 18, 2007 | 04:21 PM
max4evr's Avatar
Re: mileage on the car
[QUOTE=matty]Mileage on the car ??
Got 125K on car/original hoses now.
Guess the heater hoses don't need replacing now because they deteriorate only when the heater is on? I thought maybe the engine heat would kill them, but maybe not. It's sure a lot better rubber than they used back in my old Datsun days!
Old Aug 18, 2007 | 07:28 PM
I would say it's time to change them.
Old Aug 18, 2007 | 08:50 PM
67whitegoat's Avatar
If they are crunchy, definitely change them. Why wait till your on the side of a road somewhere. A little preventive maintenance goes a long way.
Old Aug 18, 2007 | 08:51 PM
hybridc24k's Avatar
replaced at 178K
Old Aug 18, 2007 | 11:20 PM
chillin014's Avatar
see, now there is someone with logic that makes SENSE.^^
One of my heater hoses cracked and spewed fluid all over my engine bay, and the car over heated at like 2 AM in the morning when I was heading home. Do you still want to take the chance after hearing that?
coolant flows through the heater core whether your using the heater or not...
Old Aug 19, 2007 | 10:36 AM
jazzman's Avatar
I had the water pump go bad after about 246k.. I replaced that and the radiator , because it had a crack in the top plastic tank. Soooo.. I replaced both rad. hoses, belts, thermostat housing.. etc. Not worth trying to be cheap on the cooling system..
Old Aug 26, 2007 | 10:45 PM
FishyMan's Avatar
What type of hosing did you use? Where is the heater hose located?
BTW, how much am I looking at for OEM?
Old Aug 27, 2007 | 06:19 AM
jvckustumz's Avatar
has anyone tried putting the aftermarket kind on, the kind that is a metal looking one that has red and blue ends and threads on???
Old Aug 27, 2007 | 09:33 AM
speed racer's Avatar
Its also good to replace the bypass hose. Its on the engine block driver side behind the radiator fans.
Old Aug 29, 2007 | 05:13 PM
FishyMan's Avatar
any body cna recommend what other hose to replace? thanks.
Old Aug 29, 2007 | 05:28 PM
CRiME's Avatar
oem ftw!
i saw some steam coming from that area, and noticed that hose was swollen and about to explode. I didn't know what it was called, though, so thanks for that info. guy @ autozone gave me a hose that worked, but is slightly too narrow. going to get the correct one probably this weekend now that i know what to ask for.
rbuswell
Nov 17, 2016 04:54 AM
cruce91
Sep 20, 2015 10:23 AM
MichMaxFan
Garage and Workshop
Sep 2, 2015 06:35 AM
lux97Max
19
Aug 27, 2015 07:48 PM
scarletsosa
Aug 17, 2015 09:09 PM
