A couple of questions I'm hoping you guys can help me out on a few things.
Old Aug 20, 2007 | 08:32 AM
HarrisH's Avatar
My car is a '97 with 168K miles.
The driver side window has started making a very slight noise when going up and down. The passenger side window slows down when going up 3/4 of the way up, it does not however make any weird noise.
My locks also don't unlock with the remote in the winter.
My steering rack & pinion was leaking previously in the winter it is not leaking anymore but I still feel as if I should replace it.
What do you guys suggest I do?
Old Aug 20, 2007 | 08:55 AM
JtzMax's Avatar
Whatchyou say?
the seals in the rack will probably not leak in hot weather (but in cold, they shrink up and that allows fluid to leak out) so ... I would try to get it fixed before the winter. Kevlo did a write up on How To ... if ya search, wasn't too long ago either.
as for the windows ... I'd guess they need to be re-greased. pull the door pannel and remove the plastic liner. apply axle grease to the slide arms. could be the motor is weakening too ... but I would guess it's more a binding issue.
the locks ... work in hot weather? oddddddd ... ????
cheers, hope some of this helps!
Old Aug 20, 2007 | 09:07 AM
HarrisH's Avatar
I stated that wrong, they work in the winter and summer but in the winter they partially unlock so I have to hit the unlock button again. They don't open and close all the way, they stick.
Old Aug 20, 2007 | 09:33 AM
67whitegoat's Avatar
I would not apply axle greese. Use a dry lubricant. Something teflon based is best.
Old Aug 20, 2007 | 11:11 AM
Fr33way™'s Avatar
Wild for Width
I think the battery in your transmitter may be going. Cold weather is harsh on those smaller batteries.
LilVito
Oct 25, 2019 08:12 AM
maxipower
Aug 21, 2015 11:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
yat70458
Aug 3, 2015 01:16 PM
