This hot normal?
Old Sep 9, 2007 | 02:01 PM
t65k3's Avatar
Still Learning
This hot normal?
It has been 100 degree or more during the day at where I am.
If I let the engine run idle for, say, 20 minutes with the air on, the temperature on the gauge actually goes up , not bad enough to go into the red zone, but the needle is pointing like 10 to 11 oclock. As soon as I start to drive, the temp would drop back to 8 to 9 oclock. However, the car makes very noticeable rattling sound (click, click, click.......) when I hit gas. It would go away when the RPM hits 2K. I was told that is due to bad gas, but that would not happen when the engine is cold. And I am now running on 89 Shell gas.
One of the fan (the left one when you stand in front of the car) will turn on when the air is on. But even the temp went up that high while idle, the right one didn't get turned on. Will that fan be on when I put the gear into drive?
Thanks.....
Old Sep 9, 2007 | 05:30 PM
jstew's Avatar
This may seem obvious, but what does your coolant level look like? Can you tell if the coolant is moving through the cooling system properly?
I had a car do the same thing a few years back and it was water pump related. The blades of the pump actually rusted off a bit and the coolant would not circulate properly until I hit higher RPMS. And yes, both fans should be on. IIRC, they are on my max when it heats up.
Old Sep 9, 2007 | 05:40 PM
MOHFpro90's Avatar
Both of my fans spin while at idle in park... :\
Old Sep 9, 2007 | 05:44 PM
NmexMAX's Avatar
dot dot dot ...
Your fan is dead. Fix it and watch your temp needle chill out.
Old Sep 9, 2007 | 06:07 PM
t65k3's Avatar
Still Learning
I added some coolant to let it reach "MAX" in the reservior a couple weeks back. The level is normal now.
Looks like the fan is dead for sure, plus I need to check the pump......
Thanks....
Old Sep 9, 2007 | 06:28 PM
heynow's Avatar
my question would be: Why the hell would you be idling with the AC on for 20 mins?
Old Sep 9, 2007 | 06:31 PM
wirelessdude04's Avatar
lol to burn gas lol
Old Sep 9, 2007 | 07:14 PM
t65k3's Avatar
Still Learning
Gals never on time..... sigh~ I'd be pretty lucky that day if it's only 20.
Old Sep 9, 2007 | 08:09 PM
heynow's Avatar
lol, i know how that is man. But not only are you wasting gas, you're asking for overheating when you're standing still running the AC. (not to mention the cat-converter) Just do what i do, shut off the car, and hang around.
Old Sep 9, 2007 | 08:17 PM
pmohr's Avatar
No more Maximas...
With a properly functioning cooling system, you could idle forever (given you had gas) without overheating.
And what about the converter? Please do mention it.
Old Sep 9, 2007 | 08:48 PM
MOHFpro90's Avatar
You're in PA, he's in Al. I can speak for most southern states when I say turning off your car is like living in hell. Oh wait, it is hell. Not having an AC sucks, so I would definitely get that fan checked out/replaced.
Actually, FL weather has been nice lately, mid 80s on avg for the highs, humidity is still high though.
Old Sep 10, 2007 | 06:42 AM
heynow's Avatar
yeah, well, just so you know, we've had 95 degree weather with 90% humidity, so lets not get too technical here. pmohr, i think i remember reading in the manual, that extended periods of "idling" put a lot of stress on the cat. Seeing how it is an older car, i wouldn't want to put extra stress on ANYTHING. But, to each is own.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
