96 auto trans
Old Jul 24, 2001 | 12:35 PM
jack
what maintenance is required in regards to this transmission. does the fluid need to be changed...is there a filter?
also the rims on my 96 gle appear to be flaking, what causes this and are there any recalls in regards to this?
Old Jul 24, 2001 | 01:41 PM
Daniel B. Martin's Avatar
Originally posted by jack
what maintenance is required in regards to this transmission. does the fluid need to be changed...is there a filter? ...
The Owner's Manual does not call for replacement of transmission fluid unless you tow a trailer, use a camper or car-top carrier, or drive on rough/muddy roads. In severe service such as this, replace the transmission fluid every 30K miles or 24 months. This holds for automatic or 5-speed transmissions.
The 4Gen Maxima automatic transmission does not have a true filter. There is an internal screen but it does not require cleaning or replacement.
That said, many Maxima owners elect to make a transmission fluid change part of their 60K mile service procedure.
There are two methods for changing the Automatic Transmission Fluid.
Method 1) An ordinary drain-and-refill may be done by the home mechanic. This method changes only about half of the fluid, but is easy and inexpensive. The cost is 4 or 5 quarts of ATF, plus your time.
Method 2) Most commercial service facilities use the Magic Sucker Pump which changes all of the fluid. The cost is about US$80.
My Maxima is a 5-speed so the issue of ATF change does not apply. I maintain a Honda Accord for a family member. On that car I do a drain-and-refill ATF change with every oil change. It is not a big deal, as the car is already up on jackstands and my hands are already dirty. This costs about US$8/year in ATF and the car is always running on almost-new ATF.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
