somtimes my 5spd max does not want to engage in reverse...
Two things you can do...
First, let the car drift forward or backward for about two inches, and you should be able to get the car into gear.
Or
You can shift into first (or second, then to first if first is blocked out as well), then shift back into reverse (all without letting out the clutch). When you go back to reverse, you'll be able to get in.
I think it has to do with the syncros...
Or
Or
Or
Perhaps you are waiting too long between disengaging the clutch and moving the gear shift lever. When the clutch is disengaged and the vehicle isn't moving, all the rotating components in the transmission slow down and then stop. Shifting into a synchronized gear becomes more difficult in this situation.
Try flooring the clutch pedal and shifting into Reverse immediately. That may help.
When I first started driving a stick, I always either grinded into reverse, or sometimes had trouble engaging all the way in reverse. For me, putting it into a forward gear and then back to reverse quickly solves both of these issues. Sometimes in my Acura, it takes a few tries to get it fully engaged in reverse, but I just sit there and move it into different forward gears and back into reverse.
hmm
I always thought the problem was because the reverse gear *has no* synchronizer. This is why you have to time it just right, and sometimes it will grind if the engine is running too fast (try blipping the throttle just before you put it in reverse, it ain't pretty)
Justin
Justin
thats right... the reverse gear lacks synchromesh ... well from what i know... and it is naturally tougher to get into gear unless you shift quickly and with some force...
we all have that problem... so yea just shift quicker or roll a coup[la feet in neutral that should help
Re: hmm
Originally posted by justmax
I always thought the problem was because the reverse gear *has no* synchronizer. ...
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
ef9
Oct 4, 2015 08:43 AM
