Whats up Steve !
Old Jul 29, 2001 | 05:40 PM
190hpKiLLA's Avatar
Granny Driven
How did u get home? Medisonic wants a 5spd after driving mine. Anyway I bought the 1156 bulb and filed one of the 2 nipples that were located closer to the bulb it self. And it dint work, what i noticed is that the bottom of the bulb where the connectors go had only 1 nipple and stock has 2. So whats up with that. I got so ****ed, because everything went wrong. The HEadlights i brought are bad and now these corners suck. Please help...
Old Jul 29, 2001 | 06:26 PM
BlkStnValyMaxima's Avatar
You must have broke it man. My bulbs worked fine that way on Deezo's car and they work fine on mine. And yes they do have 2 connectors on the bottom and not 1, so I don't know what's going on there.
Old Jul 29, 2001 | 06:38 PM
sleeper's Avatar
corners?
are you talking about the clearance lights?the ones next to the headlights?
Old Jul 29, 2001 | 06:44 PM
190hpKiLLA's Avatar
Granny Driven
Ye i am Talking about the 1ns near headlight
U see i guess i need 1156 with 2 connectors because while back i was going to but them and the guy didnt know if i had 1 or 2 connectors. I should go to the store and get the 2 conn.
Old Jul 29, 2001 | 06:55 PM
sleeper's Avatar
clearance lights
the light bulb is a 1157. 2 filaments. the socket has 2 connections, but only one side has a wire connected to it. and it uses the low watt side of the bulb. to get it to use the other side(higher watt) you have to take the wire out and solder it to the other hole in the socket. then it will use the higher watt filament. what i did was solder both sides together with a piece of wire so they both are on, but they do get hot. so i don't recommend it. although there is a lower watt 1157 available from summit racing to equal 26 watts instead of 40 watts. part#grm-m-14 so i can use that one and it won't be so hot. peace out.
Old Jul 29, 2001 | 07:23 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Ok here's the deal. he's talking about the clearance lights, the cornering lights. same thing. yes the stock housing has 2 connectors on the bottom, one for 27watt and one for 8 watt. the 1157 bulb has both filaments but only one the 8 watt works on the 97-99. so the EASY way to fix this is to buy a ONE connector 1156 bulb and file off one of the nubs on the side and viola! 27 watt bulb at 27 watts, i did it this morning in under 5 minutes for deezo.
Old Jul 29, 2001 | 08:40 PM
Sonic's Avatar
2 Maximas are in my future, one 5 speed, one SC'd auto. It'll happen before the end of the year. BTW, nice car Val, and good luck with the lights.
Old Jul 29, 2001 | 08:45 PM
Craig Mack's Avatar
All YOUR grammer belong to me
MedicSonic, Nooooooooooooo
Hey, M.S., I remember the post about the 5spd conversion in Jax, and you saying "Nice, But I'll keep my car AUTO"...what happened to that ?? Are you converting too ?? After a valve body upgrade shouldnt your auto be so close to a manual ? Tell me about your experiance.
Old Jul 29, 2001 | 09:08 PM
_DRU_'s Avatar
uumnm.. when you put the light bulb back in, you have to put it in backwards so the lowest nipple on the bulb will go in the halfway nipple spot.. know what i mean? IM me at 'Its Like Wu' if you have any questions... good luck
Old Jul 29, 2001 | 10:09 PM
Sonic's Avatar
Uh Craig, I said 2 Maximas, one auto (the current one) with the SC and a 5 speed.
Old Jul 30, 2001 | 07:07 AM
AndyXXL's Avatar
So you really think about SCing your current Max? I started thinking about that too.
Old Jul 30, 2001 | 07:18 AM
Sonic's Avatar
Yeah, I did alot of thinking last night, and SC the car will be better than buying a 5 speed and doing it. The car is alrady starting to get modified and I think that a SC in an auto is 'cooler' anyway. I am looking for a fully optioned 5 speed SE from about '97 on. I'm going to start seriously searching in about October.
Old Jul 30, 2001 | 07:37 AM
AndyXXL's Avatar
So what do you need to SC an auto? A tranny cooler, VB mod, what else? My only concern is auto tranny. I don't wanna blow it with that SC.
Also, what sc are you considering, a V1 or V2?
Old Jul 30, 2001 | 08:21 AM
deezo's Avatar
The HEadlights i brought are bad ..........
You mean bad = good right? If you look at my sig pic, this is when I had them installed.
Old Jul 30, 2001 | 04:42 PM
190hpKiLLA's Avatar
Granny Driven
NO!
The headlights I got from you are not good, because the foggy one is less bright. I took them out. If u want I could send them to you for a refund. When you put the foggy bulb in it looked good comparing to yours, but when u put both of them in you could see the difference. No hard feelings...
Old Jul 30, 2001 | 04:53 PM
AndyXXL's Avatar
Re: NO!
Damn, that sucks.
Old Jul 30, 2001 | 05:00 PM
190hpKiLLA's Avatar
Granny Driven
Igot my original bulbs to be brighter!
I filed off the top nipple and they got brighter, i realised that i should of turned the bulb around in order to make it work. Thanks..
Old Jul 30, 2001 | 05:14 PM
Sonic's Avatar
Good job Val. Andy, pretty much all you CAN do is the VB and the tranny cooler. I'm going for what's available, but the V1 whine to me is annoying, the V2 is quieter. I guess I'll go V2.
Old Jul 30, 2001 | 05:20 PM
190hpKiLLA's Avatar
Granny Driven
Re: Igot my original bulbs to be brighter!
You definatly need a sc. Then Steve will be behind with his NOS->.
Old Jul 30, 2001 | 08:02 PM
Re: Re: Igot my original bulbs to be brighter!
not really, i will have a shift kit on the way this week and the pump tomorrow and a 100shot next week maybe. little tuning and hello 13's.
Old Jul 30, 2001 | 08:23 PM
190hpKiLLA's Avatar
Granny Driven
1- Are u sure i need 1156 bulb and it has only 1 nipple on the bottom. What if i use 1157 with shaved upper nipple on the side. Which is better.
2-How to make a signature pic. Thanks..
Old Jul 30, 2001 | 08:33 PM
i am 100% sure you need a 1156 bulb for the mod i'm talking about and you need to host your pic somewhere to have one. find a host first.
Old Jul 30, 2001 | 09:10 PM
Careful with that 100 shot Steve, youve only gone through 1 bottle.
Old Jul 30, 2001 | 09:17 PM
only, i think Synki's still on his second.
Old Jul 30, 2001 | 09:19 PM
190hpKiLLA's Avatar
Granny Driven
I have a host AOL: So how do i do it.
By the way I ordered FSTB, and Jm Wolf Pop Charger.
All I need is to get my lighting to work the same color.
Old Jul 30, 2001 | 09:23 PM
Pop Charger???? I thought you were gonna get the Cold Air Intake.
Old Jul 30, 2001 | 09:35 PM
he's like the wind! and i'm not familiar with aol, you'll have to ask someone who has aol.
how much you pay for the charger.
Old Jul 30, 2001 | 09:37 PM
Sonic's Avatar
190, type in myftpspace in the address bar, click on 'view my ftp space', then click 'upload'. Give the file a name like sig.jpg and select the correct file. Then go to the .org, click on profile and then click on 'edit options'. On the bottom, there is a place where is says signature. Put [ img]sig.jpg[/ img] there then click submit (NOTE:take out the space in from of the img above).
Old Jul 30, 2001 | 10:01 PM
190hpKiLLA's Avatar
Granny Driven
I am like a wind>>>>
I know but I thought about it and decided that its cheaper and not a b*tch to install. I rode in that kids 5spd who made 14.88.He had pop charger and it sounded pretty good. Greg Also had one and it was really nice. So for the price of one CAI I got two things. FSTB and Pop Charger. I decide to go with new. Dont want the sane thing happen like it did with the bulbs.
Old Jul 30, 2001 | 10:06 PM
190hpKiLLA's Avatar
Granny Driven
What da h*ll
My last message is here but not shown in the forum!
Old Jul 30, 2001 | 10:09 PM
Re: I am like a wind>>>>
he has an apexi WS catback too. and he is a VERY good driver.
Old Jul 30, 2001 | 10:16 PM
190hpKiLLA's Avatar
Granny Driven
Re: Re: I am like a wind>>>>
I know but his exhaust was very silent. Anyway I will write u how I like it. It cant be that bad for a fraction a price.
P.S Lets have a meet by your place somewhere. A lot of maximas are there. I need more meets. Maybe I will try to assemble one in Floyed Benifield like we had half a year ago.
Old Jul 31, 2001 | 05:00 AM
AndyXXL's Avatar
Re: Re: Re: I am like a wind>>>>
Dude good luck with the intake, I hope u like it. Let me know what you think of it.
Old Aug 1, 2001 | 08:31 PM
190hpKiLLA's Avatar
Granny Driven
My engine is now ready
After work I cleaned my engine, repainted all the ruted metal pieces and sanded with light sanding paper the top of the engine to get rid of that aluminum oxidation. And i also changed my fuel filter. It was pretty clean. Now my car is ready for my pop-charger and FSTB. I got all the lights working witht hat 1156 bulb now i will change the xenon bulbs Dezoo sold me cause it get dimmer and dimmer. LAter..
Old Aug 1, 2001 | 09:34 PM
now try some engine dressing, dabox has done it, pressure wash the engine and spray this **** in there and looks new.
bigdogsteve
Jan 31, 2018 04:18 PM
Team STILLEN
Aug 10, 2015 04:29 PM
