Cleaning solution for windshield ??
My windshield is very clean when its dry out but then when it rains it gets that grimmy look to it and i can bearly see through it...I usually put rain X on it but then you have to every few months or it gets annoying...i was wondering if there is a cleaning solution i can make to clean all the debree off the window...?? you cant see it its like on the glass
its hard to explain
any help
its hard to explain any help
Had that problem
I had that problem for a while too. I also used the rainx stuff and it worked great but now that I see this I wonder if there is some conenction to the rainx and the problem. I found a resolution to the problem though do about 90 down the highway and have a rock come up and break your window. Get your windshield replaced - seemed to work for me.
SuDZ
SuDZ
Re: Had that problem
Ha ha!! That's what I did
SuDZ
SuDZ
If you're talking about when you use the washer fluid/wipers, try putting in 20/10 (that's the name of the stuff, it comes in a green bottle, I think MB uses it from the factory) into the resovoir. You don't need too much, like maybe 2-3 capfuls. It really works great in making your window super clear.
-V
-V
Try some Bon Ami or Bar Keepers Friend. Its a fine powder but it works great. I tried it on our 1986 Jeep's Winshield which had 15 years of grime on it and it helped a ton! I saw this on some detailing show on TV. This show also said you can mix up alcohol and vinegar to use but I didn't get any great results with it. The powders actually polish the glass. On the cans it says not to use on glass but I haven't had any problems. I would stronly recommend you try it on a small spot though in case something bad does happen. I have not tried it on the Maxima yet but I guess all winshields are the same??
get a product called vision blade. It's sorta like rainx however u only apply it once and it's supposed to last 6 months, but my friends say it lasts much longer than that. Just make sure you read the direction and apply it correctly otherwise u'll get streaks for the first three weeks.
Apr 16, 2020 05:15 AM
fx4five
Oct 1, 2015 04:58 AM
