engine check light problem?
Old Aug 9, 2001 | 07:52 AM
Daniel B. Martin's Avatar
When posting a technical question please provide the model year of your Maxima, the odometer reading, mods (if any), and recent repair history. A detailed report of symptoms would be helpful.
Old Aug 9, 2001 | 10:03 AM
MaxMaxima's Avatar
95 maxima se
72,000 miles
stillen high flow intake
recent accidents- some intrepid hit my front right bumper and shifted everything to the left. but the engine check light was on before that. also we replaced the muffler and catalyc converter but the light was on before that also. so any ideas?????? thanks
Old Aug 9, 2001 | 10:38 AM
Read the Sticky
Originally posted by MaxMaxima
95 maxima se
72,000 miles
The Check Engine Light is evidence that something is wrong. That "something" may be any number of things, some major and some minor. It might be nothing more than a loose fuel filler cap. The Engine Control Module (the computer) detected a problem and turned on the Check Engine Light. At the same time it stored one or more Diagnostic Trouble Codes. Get someone to do a DTC readout for you. This is not a big deal, does not require specialized "dealer only" test equipment, and should take less than an hour.
If you like to do your own "wrenching" you can do the DTC readout for yourself. No special tools are required. Read the Sticky ECU Diagnostic Trouble Codes. It contains pointers to instructions for doing the DTC readout and an explanation for some of the codes.
When you know the stored DTCs, you will have a fair idea of what repairs are needed.
Old Aug 9, 2001 | 07:48 PM
MaxMaxima's Avatar
what kind of person would know how to do one of these tests?
Old Aug 9, 2001 | 08:11 PM
You, after you read the instructions at http://vbxmaxima.8m.com/ecu.html
Old Aug 9, 2001 | 09:08 PM
MaxMaxima's Avatar
alright i got it done and the codes were
0503 and 0304 which were front right heated o2 sensor and the knock sensor do you think i should replace those or are they even important? and where would i get them replaced if i do? thanks for all the help though
Old Aug 10, 2001 | 04:02 AM
Oxygen Sensors are a vital element in the engine management system. I suggest you replace the Oxygen Sensor and reset the Engine Control Module. This one repair may clear both Codes.
JMag90
Aug 25, 2015 09:17 AM
maxinout93
Aug 20, 2015 02:17 AM
Viralkill
Aug 16, 2015 05:09 PM
Samedi
Aug 13, 2015 04:05 PM
