Tires sccccrrreeeeching !
Old Aug 9, 2001 | 07:28 AM
smackdownGTR's Avatar
It was hot as hell in NYC last night. I was making a turn under 20mph. My stock tires (Goodyear rsa) were screeching like hell. Has it happened to any of you guys??
Should I change my tires? It's been screeching since I got the car. Does it mean the tires suck? Any suggestions? I wonder if the temperature made it screech even louder.
Old Aug 9, 2001 | 08:07 AM
njmaxseltd's Avatar
Check your tire pressure. I had the RSA's on stock rims. Never heard them scream like your reporting. Unless your really pushing them HARD. Go get some 18" wheels and tries for that Max!
Old Aug 9, 2001 | 08:19 AM
mzmtg's Avatar
Minister of Silly Walks
I agree, make sure your tires are about 33/31 front/rear COLD psi. Also, make sure your alignment is correct.
Cold psi just means check it in the morning before you drive anywhere.
Old Aug 9, 2001 | 08:42 AM
Black VQ's Avatar
Not to say you can't drive or anything, but...
How is your driving style? If you suddenly jerk the wheel in any direction, you're going to upset the balance of the car...even at 20-something mph.
I don't know how hard you were trying to turn, but if you turn too hard, too suddenly, that can begin to lift the tires off the ground ever so slightly. That makes a screeching or squealing noise as well.
Old Aug 9, 2001 | 01:14 PM
Re: Not to say you can't drive or anything, but...
No dude. I was driving like an old lady. btw my tire pressure is 37/33.
Old Aug 9, 2001 | 01:39 PM
mzmtg's Avatar
Re: Re: Not to say you can't drive or anything, but...
That tire pressure may be too high, but I doubt it.
I'd say the chief suspect is an alignment problem. That, or the Maxima isnt living up to your expectations. Get an RSB or a new car.
Old Aug 9, 2001 | 03:08 PM
Sexima's Avatar
isnt it supposed to be 32 in the front and 36 for the back
Old Aug 9, 2001 | 03:19 PM
mzmtg's Avatar
that will give you ungodly horrible understeer...
(which is bad)
Old Aug 9, 2001 | 05:03 PM
phatmax95's Avatar
yeah check your alignment, since it has been doing that since you got your car, ive taken turns at 35 or more and no prob.. so im guessin your alignment is wack
Old Aug 9, 2001 | 07:55 PM
costcowholesale's Avatar
I had that problem for the past two months and I did a tire rotation last week adn the screeching was gone(my front were really worned)now no more noises above 25km/h 90 degree turn!
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
