turn signals
So that it looks a lot cleaner. For example, my turn signals in the bumper are on constant and match the side marker. The corner lamp next to the headlight matches the intensity of the headlight. It just looks a lot cleaner, and a lot sportier.
ok
Mr.loyd
the corner light is the top light next to the headlight.. its not a signal .. it doesn't blink when you put the signal on .. on 95-96 max's tho it get brigher when you put the signal on and what you can do is get it to stay that bright..
gr95: yes you can do both .. I did and it looks real good..
to rewire the corner light next to the headlight for 95-96 only just switch the postive wires...there are two positives.. just cut and switch them and reconnect..
for better insructions go to Jeff K's site .. megamax site
or Chebosto's site http://www.maximadriver.com
Ant
Ant
Re: Re: To Ant95se
Originally posted by doug
http://maximanorth.homestead.com/fil..._mods_rwts.htm
Originally posted by Gr95
How do you wire the blinkers so they come on with your parking lights and then still blink like they are made to do......
Doug, I tried that mod last nite. I don't mind it, but it still wont light the front turns with park or headlights on.
What I do get is blinking sidemarkers both W/ and W/O headlights on. Thats great, but I'm going to replace the socket for the front signals with a dual element one and wire it so I have a running light as well as a blinker. Funny, all other cars seem to have this.(???)
Jack
Turn Signals
I changed my single bulb and filament sockets in my turn signals to the dual bulb and filament sockets yesterday. Now, the turn signals are on the with the side markers but also blink when activated. Very cool. Do it, it changes the look of the car.
-Erik
-Erik
Counterproductive >>
Re: Turn Signals
-Erik
-Erik
Thanks,
Jack
Counterproductive: No lights in front!
Originally posted by Albertt
Why would you want this. The reason why they are on/off instead of dim/bright is for safety reasons. There is more discernable contrast between a bulb that blinks on/off than when it's dimly lit and blinks. There are reasons why engineers do things a certain way...sometimes you've got to trust them.
If I am wrong and Nissan is so right about this, I have GM, Ford, Crysler, Honda, etc, etc on my side. Its not too emabrrising for me to be wrong with so many.
(FWIW, I read your post about leaving corner lites on all the time, and while I agree that they should not be on all the time, I hardly think its worth a crusade over. Just my 2c)
See ya,
Jack
Re: Counterproductive: No lights in front!
[/I][/QUOTE]
You do have light facing forward besides the headlamps...your parking lamps next to the headlights. If your headlights go out...change the bulb...any light your bumper lights throw wouldn't be enough to drive by anyway.
You're right GM, Ford, Crysler, Honda, etc do use dim/bright bumper lamps, but they also apply this to many of their tailights. Another bad idea.
These are my opinions...and I'm just voicing them. Take it easy.
[/I]
[/I]
You also have Nissan on your side...
My old '91 Stanza had turn signals that worked in the "dim-bright-dim" fashion.
Didn't bother me, but I do think that it is safer the way the Max comes stock.
Albertt and Jack, [he's chillin' :) ]
Jack
Re-wiring
When you use a dual filament bulb and socket, it does not have two different shades, it is always the same color, with and without the turn signal on. Go to this site and check it out, very very simple. http://maximanorth.homestead.com/fil...mods_rwts.htm. Email with questions
-Erik
-Erik
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
