climate control upgrade on a gxe
Old Aug 11, 2001 | 10:17 PM
eyegotit
what is required to install a automatic climate control unit on a gxe? i am thinking of picking one up at a junkyard and doing it myself.
Old Aug 11, 2001 | 10:41 PM
mk dema
not sure, but if you find out, please post a link or somethin, I'd also like to do that to my GXE...
goodluck
Old Aug 12, 2001 | 07:43 AM
mzmtg's Avatar
Minister of Silly Walks
This has been discussed in the past. The general consensus was that it was too hard. Not worth the effort really. There are lots of sensors that need to be installed/replaced. You dont just switch out the unit in the dash.
But, hey, go for it...you might be the first to bother with it.
Old Aug 12, 2001 | 08:08 AM
Daniel B. Martin's Avatar
The automatic climate control is a sophisticated computer-controlled device. It relies on signals from four sensors.
- The in-vehicle sensor, attached to the A/C control finisher.
- The ambient sensor, attached to the radiator core support.
- The sunload sensor, located on the right defroster grille.
- The intake sensor, located on the cooling unit housing.
I believe this conversion is possible but costly and probably not worth the effort. To judge by past posts on this newsgroup, the automatic climate control is more failure-prone than the manual type and replacement parts are expensive.
Fbana41
Aug 29, 2016 12:18 PM
mikeg75
Nov 30, 2015 05:12 PM
Turbonut
46
Oct 21, 2015 08:28 PM
EdRomo86
Sep 12, 2015 07:49 PM
