Need help with engine mount replacement
Old Aug 21, 2001 | 12:26 PM
BriGuyMax's Avatar
ok, so I got the cattman engine mounts (front and rear) and the front mount is no problem at all....but the rear is a bit*h the bolts that hold the rear mount to the frame can't be removed because the transaxle is in the way. Any one ever dont their engine mounts WITHOUT removing the trans....please help
Old Aug 21, 2001 | 01:12 PM
QikEnuf's Avatar
man, I would love to help but my local shop installed them for me, I wasn't around when they did that, I will see if I can find out what they did for you.
BTW- mounts are great, I love'em, nice take off, very little if any wheel hop
Old Aug 21, 2001 | 01:31 PM
mzmtg's Avatar
Minister of Silly Walks
I can scan the pages in the Haynes manual if you want. Send me Email...
Old Aug 21, 2001 | 06:13 PM
sinewave's Avatar
Just drop the frame that the motor mounts sit on; there are only 4 bolts. You will have to remove the bolt(s) that passes through the center of the motor mount(s), then the whole thing should drop down.
When you put it back together, don't tighten the motor mount to frame bolts until you have all of the other bolts started. Also, don't forget to torque everyting up.
Old Aug 21, 2001 | 06:17 PM
BriGuyMax's Avatar
THANK YOU!!!! I don't know why I didn't think of that in the first place....DUH. oh well, thanks everyone for the effort...you just saved me some $$$$.
vingodine
45
May 21, 2016 12:46 PM
schmellyfart
Sep 25, 2015 04:47 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
laparka66
Aug 6, 2015 09:36 AM
