Walbro FPD006 fuel pump question
Old Aug 23, 2001 | 04:23 PM
bosco500's Avatar
I have just ordered the walbro 255 ltr/hr fuel pump. Will everyone that has this pump please respond with any information that might be helpful. I am planning on running a 3.33 pulley. I can use the stock belt right? Also will this pump do any good without upgrading injectors?
thanks
Old Aug 23, 2001 | 04:24 PM
bosco500's Avatar
also is the installation posted anywhere?
Old Aug 23, 2001 | 04:36 PM
mtrai760's Avatar
'Trynna' is not a word
Look at the How2 section of www.maximadriver.com. The fuel pump will support any mods you can think of doing, and it is effective withougt upgrading the injectors, they just control when the fuel goes in, not at what pressure. The only thing else you should need is a new fuel tank gasket. Good luck.
Old Aug 24, 2001 | 06:57 AM
bosco500's Avatar
any other run-in's with this pump?
MTRAI - Are you using this pump and is it working well for you?
Old Aug 24, 2001 | 07:10 AM
MardiGrasMax's Avatar
If you have the underhood boost fuel pump that Stillen supplied with the SC kit hooked up and working you do not need the Walbro fuel pump. The Stillen supplied fuel pump is all you need. Save your money. If you wish to remove the Stillen supplied boost pump from under the hood you can use the Walbro as an intank upgrade, this is what I did because my SC kit was used and I already had the Walbro pump installed from my nitrous work.
BkGreen97
Apr 2, 2016 05:47 AM
cruce91
Sep 20, 2015 10:23 AM
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 11, 2015 10:26 AM
