Fuel gauge question ->
Originally posted by Matt_P
Where the heck to I tap into the lines? The shop manual says use the line coming out the top of the fuel filter, however I get like a 0 psi reading out of this line if the vortech t-rex pump is on. Otherwise, it reads 37psi at idle.
Matt P.
Matt P.
I don't know what a "vortech t-rex pump" is. If this is a modification to the engine, consult with the pump manufacturer.
I guess when the boost is on, the vortex t-rex pump takes over. Where does the vortex t-rex pump fuel line ends? It has to go to the fuel rail right? I would tap it at the fuel rail then. I tap mine on tap of the fuel filter and I'm getting correct readings. On the stock max, the fuel goes from the fuel filter to the fuel rail.
Matt P.
Matt P.
I taped just before the in side of the fuel rail.
Works for me. I had to get a small hose barb "T" fitting and some hose to plumb it in. Its a tight fit but its close to the rail and provides a good preasure reading.
Yeah, the
re: I guess when the boost is on, the vortex t-rex pump takes over.
Correct.
re: Where does the vortex t-rex pump fuel line ends?
It ends right into the fuel rail supplying the middle 3 injectors.
Correct.
Matt P.
Matt P.
Re: I taped just before the in side of the fuel rail.
I am also kind of curious, if the pressure drop at the line coming out the filter is alright.
Matt P.
