Handbrake won't let go my rt. rear!
My wife came home last night in our '97 5spd with 63K miles. Thought something was on fire! The right rear wheel was HOT! After it cooled, took it off and the parking brake was not fully released. Is the recoil spring atop the caliper not doing it's job? Is cable lube required maintenance? Cable seemed to be vinyl or nylon coated inside the sheath. Didn't seem real tight. Was able to rotate the bracket by hand and release the brake. Anyone have any parking brake cable/return spring problems? Hope my pad and rotor are ok. The rotor looks a little smoother than the rest.
The heat from this dragging brake may have "cooked" the lube out of the rear wheel bearing. This will lead to a premature failure.
Originally posted by Daniel B. Martin
This could be caused by a sticking caliper.
... Should probably pull the wheel and check the lube. Would it be black if burnt or just plain gone? ...
Do you have a procedure and torques for bearing check?
... Don't have a service manual yet. ...
... You think this could be the caliper's fault not the spring? ...
The bearing is a sealed assembly. You won't be able to check the lube.
Remove the rear wheel and spin the hub. A growling sound is a bad sign. Dragging (after brake pads have been removed) is a bad sign. Axial end play (measured with a dial indicator gauge) must not exceed 0.002 inches. The torque spec for the rear axle wheel bearing lock nut is 137-188 foot-pounds.
I encourage every home mechanic to have some kind of manual. However, the sad truth is that none of the manuals gives much information about rear wheel bearings.
I think the problem could be a stuck caliper and suggest you check that while you are in there checking other things.
... Is the parking brake a mechanical link? I mean, it doesn't use the fluid pressure to move the caliper?
The hand brake is purely mechanical. The car could have lost 100% of its hydraulic fluid and the hand brake will still work. That's why it is sometimes called the Emergency Brake.
... Do you know what's involved in replacing the parking brake return spring located at the caliper? ...
No. I believe that spring is an innocent victim in this drama, not the villain. Please let us know after you have made a diagnosis and repair.
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
