Help! Sun visor keeps boppin' me on the head.
The support on my driver-side sun visor must be super-lubricated, because when I have it set to block the sun from the side window, it whacks me on the head whenever I take a left turn. Every other car I've driven has enough friction built into the visor so that it holds its position on all but the sharpest turns. Mine has almost no friction at all, so it just swings freely with the turns.
Is there a simple way to keep it from swinging around, or should I just install a new visor? Is there some sort of goop that I could put on the support that would give it a little friction?
Thanks,
-Pete
Thanks,
-Pete
Try some Coke.
Thanks,
-Pete
Thanks,
-Pete
Use an eye dropper, or Q-tip, etc. and get it in the moving joint(s) and then let it dry. Good luck Pete.
Mar 12, 2020 12:06 AM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
ef9
Sep 5, 2015 11:18 PM
