odometer
Old Oct 27, 2000 | 01:51 PM
icebergslim
I have a 95 max, how do i disconnect the odometer ???
ICEBERGSLIM. . .
Old Oct 27, 2000 | 02:00 PM
Kenneth's Avatar
OG :)
STOP THIS NONSENSE!!!
Old Oct 27, 2000 | 02:17 PM
MardiGrasMax's Avatar
Use some tin snips and cut the cable.
hehe
Old Oct 27, 2000 | 02:18 PM
Shingles's Avatar
The missing moderator
ICEBERGSLIM. . .
You do know that this is VERY illegal right?
Old Oct 27, 2000 | 06:11 PM
BrianV's Avatar
If you can't figure it out than you shouldn't even try. I mean any common sense could get it done. You might want to start with a screwdriver and start taking apart the speedo assembly. Depending on how exactly the Maxima's parts are assembled you either need to disconnect or cut the cable that goes to the mileage. There might be other taking apart that's neccessary on this car. I know two screws on the steering colum and two on the instrument roof will take a honda one out.
Old Oct 27, 2000 | 08:00 PM
Mike Cline's Avatar
ICEBERGSLIM. . .
Why would you want to do that? How would you know when to change oil, tranny fluid, etc.
Old Oct 27, 2000 | 10:06 PM
emax02's Avatar
It's real easy,
If you have a 95 or 96 max with the analog odometer you can just remove the meter fuse in the master fuse box next to you left knee.I warn you though after you do this your car will act strange I think when you remove that fuse your altinator shuts off and after you drive your car for about 20 minutes it dies and then the stinkin check engine light comes on.The way you would make this work is by after running your car for 20 minutes re-install the fuse for 5 minuted and then remove it so the battery recharges,this is a real pain in the *** but it works.I did it for a week but it was to annoying so I stopped.
Old Oct 27, 2000 | 10:07 PM
thanjp's Avatar
Does NE1 know where I can get spare VIN plates?
...I don't believe this guy...
Old Oct 28, 2000 | 11:01 AM
sx7r's Avatar
haha, spare VIN plates
Old Nov 26, 2000 | 11:51 PM
I30CeFiRo's Avatar
Uhhhh.....NO
Maxboy23
55
May 1, 2025 06:09 PM
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
Djsmaxima
Sep 14, 2015 11:58 PM
