Attn: Cumalot
The Sprint's seem to ride better than the Intrax's. I'm not too sure because I had the Koni's installed at the same time as the Sprint's. So, the Koni's might have something to do with the ride. If I had to do it over again, I would have kept the Intrax's. I say that because the Sprint's doesn't give the "claimed" 2" drop all around. Even worse, the rear sits up much higher than the front, look at my sig pic.
Re: You need more subs in the trunk....
Originally posted by BRIGBOY
...2 w3's aren't enough, just kiddin.
I got a few "big" friends, maybe I can tell them to ride in the trunk the next time we go out. That should help my car look more even overall.
Re: Re: You need more subs in the trunk....
Good times.
SuDZ
Re: Re: Re: You need more subs in the trunk....
Originally posted by MardiGrasMax
I'm not gettin in your godam trunk!
SuDZ
Re: Re: Re: Re: You need more subs in the trunk....
Originally posted by SuDZ
Lure him in with snacks and then shut it quick. Once he is in just put down the trapdoor in backseat for extra air. If he bounces around enough it may even look like you hooked up Hydrolics. HeHeHe
SuDZ
SuDZ
However sacks of hydrophonic will do the trick
Vesaijan
Feb 27, 2002 01:03 PM
